Plecto
Full Member level 5
- Joined
- Jan 4, 2012
- Messages
- 315
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,298
- Activity points
- 4,979
I've made a few of these class A headphone amplifiers, but I got a weak humming in my latest design that I can't quite figure out the source of. I have a star grounding and a torodial transformer. The humming is constant, it does not depend upon the setting of the volume pot and it doesn't even depend upon gain! I have a button that switched between a gain of 5 and 15 (if I remember correctly), but pressing this button doesn't change the volume of the humming If this was a grounding issue, the humming should have changed with gain so I'm thinking that the noise is coupled directly to the output or something, but I'm not even sure if that's possible Here's the schematic and board layout:
I've highlighted the ground scheme. Mind that the component values in the schematic are NOT correct. I will upload a new schematic with the correct values if it becomes relevant. R22, R23 and R27 are 0Ohm jumper resistors. The op-amp is a TLE2142.
