[PIC] HD44780 read busy flag (mcu = PIC24FJ128GA010)
28ward28
Newbie level 2
Newbie level 2
I have got my 4x20 LCD working so I can write data to it but I cannot succesfully read the busy flag.
This is a 3.3v PIC so I am using open drain outputs and 5v tollerant inputs.
After scoping the Enable and D7 lines I can see the D7 level is low when it should be reading but my routine (lcd_status) always returns 1. I have been trying all manner of things as you will see by the commented out lines but to no avail. I'm starting to think the LCD may be faulty!
Have I missed something around the reading of the MSB (busy flag) in the "lcd_status" routine?
I have included the whole code I am using in the developement of the driver in case I have done some wrong initialisation somewhere.
There is some other stuff in the code that drives the Explorer16 LCD and reads an ADC input, all of which works fine.
#include "p24Fxxxx.h"
#include "delay.h"
#include "LCD.h"
#include "LCD.c"
#include <stdio.h>
#include "temp_table.c"
#include "temp_interp.c"
#include "adc_interp.c"
    _CONFIG1(
        JTAGEN_OFF &    //JTAG off
        GCP_OFF &       //code protect off
        GWRP_OFF &      //write protect off
        COE_OFF &       //clip-on emulation mode off
        FWDTEN_OFF &     //watch dog timer
        ICS_PGx2 &      //ICD pin selects
        BKBUG_OFF)      //debug mode
    _CONFIG2(
        FCKSM_CSDCMD &  //Disable CLK switch and CLK monitor
        OSCIOFNC_OFF &  //OSCO or Fosc/2
        POSCMOD_HS &    //oscillator mode - HS
        FNOSC_PRIPLL)   //Primary oscillator with 4x PLL = 32MHz
#define AN0  0b0000
#define AN5  0b0101
void initAdc1(void)
	//AD1PCFGH/AD1PCFGL: Port Configuration Register
	TRISBbits.TRISB0 = 1;		// RB0/AN0 set as input
	TRISBbits.TRISB5 = 1;		// RB5/AN5 set as input
    AD1PCFG = 0XFFFF;			// Set all channels to digital mode initially
    AD1PCFGbits.PCFG0 = 0;  	// then set AN0 as Analog Input
	AD1PCFGbits.PCFG5 = 0;  	// then set AN5 as Analog Input
  	AD1CON2bits.VCFG = 0b000; 	//ref voltage is AVdd & AVss (on chip supply REF): 3 bits, 13-15
	 // ADC Clock is derived from Systems Clock - bit15
    AD1CON3bits.ADRC = 0;
	// ADC Conversion Clock Tad = Tcy*(ADCS+1)/2 = 32M*(0+1)/2 = 16MHz
    //                          = 62.5ns {16MIPS with PLL}
    // ADC Conversion Time for 10-bit Tc = 12*Tad = 750ns
    // Tsamp + Tconv = 4*Tad + 12*Tad = 1us (1MHz)
    AD1CON3bits.ADCS = 0b00000000;  // fastest
    // Auto Sample Time = 4*Tad. Bits 8-12
    AD1CON3bits.SAMC = 0b00100; // irrelevant in this example as auto mode not set
    // Data Output Format: Integer
    AD1CON1bits.FORM   = 0b00;
	// Clearing SAMP bit ends sampling and starts convertion
    AD1CON1bits.SSRC   = 0b000;
	// Auto Sample Time = 4*Tad. SAMC bit2
    // SMPI must be 0. Interupts at the completion of each sample/convert sequence NB. Interupts do not have to be enabled!
    AD1CON2bits.SMPI   = 0;  // irrelevant in this example as AD interupts are disabled
	// Do Not scan input selections
 	AD1CON2bits.CSCNA   = 0;
	// Always use MUX A input mux settings
	AD1CON2bits.ALTS   = 0;
    // ADC Sample Ctrl: Sampling begins when SAMP bit is set
    AD1CON1bits.ASAM   = 0;
 	//AD1CHS: A/D Input Select Register - if more than 1 channel used this best put in to another place to have code control
    // MUXA +ve input selection (AIN0) for CH0 - 4 LSBs ie. 0b0000 = AN0. NB these 4 bits are removed from here and used in main
	// bits 4-6 not implimented
    // MUXA -ve input selection (internal Vref-) for CH0: bit 7 = 0
    AD1CHSbits.CH0NA = 0;
    IFS0bits.AD1IF = 0;         // Clear the A/D interrupt flag bit
    IEC0bits.AD1IE = 0;         // Disable A/D interrupt or it screws up when its not handled!
    AD1CON1bits.ADON = 1;       // Turn on the A/D converter
//-------------------------------------------------------LCD 4x20 start
#define LCD_RS LATCbits.LATC1
#define LCD_RW LATCbits.LATC2
#define LCD_EN LATCbits.LATC3
#define LCD_D4 LATDbits.LATD0
#define LCD_D5 LATDbits.LATD1
#define LCD_D6 LATDbits.LATD2
#define LCD_D7 LATDbits.LATD3
#define CMD 0
#define DATA 1
#define WRITE 0
#define READ 1
#define STROBE_HIGH 1
#define STROBE_LOW 0
//#define	LCD_STROBE	((LCD_EN = 1),(LCD_EN=0))
 * Function: lcd_write_byte - writes one data byte to LCD
 * Params: one byte of data
 * Uses:
 *   Functions:  delay_us
 *   Variables:  unsigned char adr - to store address to send cursor to
void
lcd_write_byte(unsigned char data)
	LCD_RW = WRITE;
	LCD_D4 = ((data & 0x10) ? 1 : 0);
	LCD_D5 = ((data & 0x20) ? 1 : 0);
	LCD_D6 = ((data & 0x40) ? 1 : 0);
	LCD_D7 = ((data & 0x80) ? 1 : 0);
	LCD_EN = STROBE_HIGH;
	delay_us(1);
	LCD_EN = STROBE_LOW;
	LCD_D4 = ((data & 0x01) ? 1 : 0);
	LCD_D5 = ((data & 0x02) ? 1 : 0);
	LCD_D6 = ((data & 0x04) ? 1 : 0);
	LCD_D7 = ((data & 0x08) ? 1 : 0);
	delay_us(1);
	delay_us(40);
 * Function: lcd_gotoxy - place cursor at coords x , y
 * Params: unsigned char x, y - the co-ords to place cursor at
 * Uses:
 *   Functions:  lcd_write_byte - to to send data to LCD
const unsigned char lcd_ctl_yadr[4] = {0x00, 0x40, 0x14, 0x54};	//constants for x,y placement
void lcd_gotoxy(unsigned char x, unsigned char y)
	unsigned char adr;
	LCD_RW = WRITE;
	LCD_RS = CMD;	//write command
  	adr = lcd_ctl_yadr[y];
	adr += x;
	adr += 0x80; // add command "load DD RAM address counter"
	lcd_write_byte(adr);
 * Function: lcd_status() - reads the status byte from the disp ctrl
 * Params: none
 * Returns unsigned char - status of BF, 1 = busy, 0 = ready for next operation
 * Uses:
 *   Functions:
 *   Variables:  unsigned char ret - status bit
	unsigned char lcd_status(void) {
	unsigned char ret = 0;
	TRISD |= 0b0000000000001111;	//PortD 3:0 as input
	LCD_RW = READ;
	LCD_RS = CMD;
//	LCD_RS = DATA;
	delay_us(40);
	delay_us(40);
//	ret = PORTDbits.RD3;
	ret = LCD_D7;  // pin-portD3 of micro = D7 bit from LCD
	delay_us(10);
	delay_us(1);
	delay_us(40);
		//dummy read out of low order nibble
	delay_us(1); // or next access of LCD might fail if its immediately on RTS. Must wait for LCD_EN low strobe
	LATA = 9;
	TRISD &= 0b1111111111110000;	//PortD 3:0 outputs
	LCD_RS = DATA;
	LCD_RW = WRITE;
//	ret = 1;
  //LCD_CTL_RS = LCD_CTL_COMMAND;
//  PIN_WRITE(LCD_CTL_RS, LCD_CTL_COMMAND);
  //LCD_CTL_RW = LCD_CTL_READ;
//  PIN_WRITE(LCD_CTL_RW, LCD_CTL_READ);
  return (ret);
//----------------------------------------------------------------LCD 4x20 config stop
int main (void)
	TRISA = 0X00;
	LATA = 0;
//----------------------------------------------------------------LCD 4x20 initialisation from power ON start
	LATD = 0;
	ODCD &= 0b0000000000001111;	//PortD 3:0, 1 = open drain
	TRISC &= 0b1111111111110001;  //PortC 3:1 outputs
	ODCC &= 0b0000000000001110;  // 1 = open drain
	LCD_RS = CMD;  // Instruction
	LCD_RW = WRITE;  // Write
	delay_ms(15); // Power ON delay
	LCD_D4 = 1;
	LCD_D5 = 1;
	LCD_D6 = 0;
	LCD_D7 = 0;
	LCD_EN = 1;
	delay_us(1);
	LCD_EN = 0;
	delay_ms(5);
	LCD_EN = 1;
	delay_us(1);
	LCD_EN = 0;
	delay_us(100);
	LCD_EN = 1;
	delay_us(1);
	LCD_EN = 0;
	delay_ms(5);
	LCD_D4 = 0;
	LCD_EN = 1;
	delay_us(1);
	LCD_EN = 0;
	delay_us(40);
//--------------------------------------------------------------LCD 4x20 init continued in 4bit mode continue
	lcd_write_byte(0x28); 	// write 0x28 - 4 bit mode, 5 x 8 font, 2 lines (duty factor = 1/16)
	lcd_write_byte(0x0C);	// display ON
	lcd_write_byte(0x06);	// entry mode advance cursor
	lcd_write_byte(0x01);	// clear display
//	if (lcd_status() == 1)
//		delay_ms(2);
//	while(lcd_status() == 1 )
//		asm("NOP");		// trying to use busy flag instead of a fixed delay (below)
//	while(lcd_status());
	delay_ms(2); // from data sheet >1.64MS
//---------------------------------------------------------------LCD 4x20 write chars continue
	lcd_gotoxy(0,2);
	LCD_RS = DATA;	// write characters
	lcd_write_byte(0x42); // write char = B
//---------------------------------------end of LCD 4x20 stop
	int adc_val1, adc_val2, temp;
    char buff[5];
	char length, dp, test;
	length = 6;
	dp = 1;
	signed char y1, y3;
	int x1, x2, x3, i;
    float y2;
// Disable Watch Dog Timer
	RCONbits.SWDTEN = 0;
// Peripheral Initialisation
   	initAdc1();		// Init the A/D converter to convert Channel 0
	initLCD();
    while (1)      // Infinite loop
		//clrLCD();
//------------------------------------AD read section---------------------------
		AD1CHSbits.CH0SA = 0;
		AD1CON1bits.SAMP = 1;	//start sample
		delay_us(10);			//wait for sampling time to elapse, ie.750ns
		AD1CON1bits.SAMP = 0;	//stop sample & start conversion
		while (!AD1CON1bits.DONE);  //wait until conversion done
		adc_val2 = ADC1BUF0;		//then get value
		adc_val1 = adc_val2 >>2;
		temp = temp_table[adc_val1];
    	LCDgotoXY(0, 0);
    	sprintf(buff, "%*.*f", length, 0, (double) temp); //first "*" points to the  length. ".*" points to dp and "f" is "floating point to fixed point"
		putsLCD(buff);
	//	LCDgotoXY(0, 5);
 		putLCD(0xDF); //HD44780 character map - degree symbol
		putsLCD("C");
//		delay_ms(500);
		i=0;
		adc_val2 = 0x03ff - adc_val2;
        while (adc_val2 > adc_interp[i]) //determine lookup table index, point to location just above actual tenperature
   			i++;
   	//	if (i > 0 && i < 35) //prevent divide by zero and off table errors later
        x1 = adc_interp[i-1];
   		x2 = adc_val2;
     	x3 = adc_interp[i];
      	y1 = temp_interp[i-1];
      	y3 = temp_interp[i];
   		//  y2 = ((float)temp - (float)adc_interp[i-1]) * ((float)temp_interp[i] - (float)temp_interp[i-1]); //have to make this calculation in two parts as compiler fails otherwise.
  		//  y2 = ((float)temp / ((float)adc_interp[i] - (float)adc_interp[i-1])) + (float)temp_interp[i-1];
   		y2 = (x2 - x1) * (y3 - y1); //have to make this calculation in two parts as compiler fails otherwise.
   		y2 = (y2 / (x3 - x1)) + y1;
		LCDgotoXY(1, 0);
    	sprintf(buff, "%*.*f", length, dp, (double) y2); //first "*" points to the  length. ".*" points to dp and "f" is "floating point to fixed point"
		putsLCD(buff);
	//	LCDgotoXY(0, 5);
		putsLCD("C");
		delay_ms(500);
//--------------------------------------------------------------------LCD 4x20 testing area within infinite loop
//	lcd_write_byte(0x01);	// clear display - needs 2ms delay so busy flag should be set
//		delay_ms(2);
	//	test = lcd_status();
		test = test + 49;
		lcd_write_byte(test);
		lcd_write_byte('C');
//		lcd_write_byte(test);
//		test &= 0b00000001;
//		test += 34;
		LCDgotoXY(1, 8);
		sprintf(buff, "%*c", length, (char) test);
		putsLCD(buff);
//LATA = 4;
OK, probably expecting a lot with the dump of code I pasted!
Not to be one that gives up easily I continued checking my code and found a couple of errors:
1. I declare the lcd_status routine as void when I was expecting a reurn from it.
2. I was reading the port Latch instead of the port when reading the busy flag.
I now got it working so have tidied up the code and here it is, enjoy.
#include "delay.h"
#include <stdio.h>
    _CONFIG1(
    _CONFIG2(
#define LCD_RS LATDbits.LATD4
#define LCD_RW LATDbits.LATD5
#define LCD_EN LATDbits.LATD6
#define LCD_D7in PORTDbits.RD3	// for Reading input level of busy flag
#define CMD 0
#define DATA 1
#define WRITE 0
#define READ 1
//-------------------------------------------------------LCD 4x20LCD routines
 * Uses:
void
	LCD_RW = WRITE;
	delay_us(1);
	delay_us(1);
	delay_us(40);
 * Function: lcd_puts - write a string to the LCD
 * Params: unsigned char pointed to by s
 * Uses:
 *   Variables:  char ch - temporary store of char from string
void lcd_puts(const char *s) {
	register char ch;	// "register" is a compiler directive asking to store the data in a CPU register if available - optimization!
	while((ch = *(s++)))
		lcd_write_byte(ch);
 * Uses:
const unsigned char lcd_yadr[4] = {0x00, 0x40, 0x14, 0x54};	//constants for x,y placement
	unsigned char adr;
	LCD_RW = WRITE;
  	adr = lcd_yadr[y];
	adr += x;
	LCD_RS = DATA;  // reset default, LCD expects data
 * Params: none
 * Uses:
 *   Functions:
	LCD_RW = READ;
	LCD_RS = CMD;
	delay_us(1); //wait at least one instruction cycle of the LCD
	delay_us(1);
	ret = LCD_D7in;  // pin-portD3 of micro = D7 bit from LCD = busy flag
	delay_us(1);
	delay_us(1);
	delay_us(1);
	LCD_RS = DATA;
	LCD_RW = WRITE; //default states
  return (ret);
 * Function: lcd_clr() - clears LCD display and returns cursor to 0:0
 * Params: none
 * Uses:
 *   Functions:  delay_ms
 *   Variables:
void lcd_clr(void)
	LCD_RS = CMD;
	LCD_RW = WRITE;
	while(lcd_status());	//wait until busy flag clears
//----------------------------------------------------------------LCD 4x20 routines
int main (void)
	TRISA = 0X00;
	LATA = 0;
//---------------------------------------4x20LCD power on initialisation
	TRISD &= 0b1111111110000000;	//PortD 3:0 outputs
	LATD = 0;
	ODCD  |= 0b0000000001111111;	//PortD 3:0, 1 = open drain
	LCD_D4 = 1;
	LCD_D5 = 1;
	LCD_D6 = 0;
	LCD_D7 = 0;
	LCD_EN = 1;
	delay_us(1);
	LCD_EN = 0;
	delay_ms(5);
	LCD_EN = 1;
	delay_us(1);
	LCD_EN = 0;
	delay_us(100);
	LCD_EN = 1;
	delay_us(1);
	LCD_EN = 0;
	delay_ms(5);
	LCD_D4 = 0;
	LCD_EN = 1;
	delay_us(1);
	LCD_EN = 0;
	delay_us(40);
	lcd_clr(); // NB. lcd_clr sets LCD to expect character data, RS=DATA, on exit.
		lcd_clr();
		lcd_gotoxy(2,1);
		lcd_write_byte(0x45); // write char
		delay_ms(1000);
		lcd_clr();
		delay_ms(500);
If the while loop in the lcd_status routine is edited out the LCD does not display anything as the clear command takes 1.6ms.
