[AVR] ''hd44780 controller received data whilst busy'' error in proteus
nashalj
Newbie level 3
Newbie level 3
hi everybody
i have a problem to simulate my code-vision code in Proteus, when i start simulating, it's come error same as title, my code an Proteus image is below, please help me to solve it.
thanks in advanced.
This program was created by the
CodeWizardAVR V3.04 Evaluation
Automatic Program Generator
© Copyright 1998-2013 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date    : 19/05/2014
Author  :
Company :
Comments:
Chip type               : ATmega32
Program type            : Application
AVR Core Clock frequency: 8/000000 MHz
Memory model            : Small
External RAM size       : 0
Data Stack size         : 512
#include <mega32.h>
#include <delay.h>
// Alphanumeric LCD functions
#include <alcd.h>
// Declare your global variables here
unsigned char newchar1[64]={
0x1f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x1f,0x1f,0x00,0x00,0x00,0x00,0x00,0x00,
0x1f,0x1f,0x1f,0x00,0x00,0x00,0x00,0x00,
0x1f,0x1f,0x1f,0x1f,0x00,0x00,0x00,0x00,
0x1f,0x1f,0x1f,0x1f,0x1f,0x00,0x00,0x00,
0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,0x00,0x00,
0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,0x00,
0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,
unsigned char i, j, k;
void define_char(unsigned char *pc)
int i, a;
a=0x40;
for (i=0; i<64; i++)
    lcd_write_byte(a++, *pc++);
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Function: Bit7=Out Bit6=Out Bit5=Out Bit4=Out Bit3=Out Bit2=Out Bit1=Out Bit0=Out
DDRA=(1<<DDA7) | (1<<DDA6) | (1<<DDA5) | (1<<DDA4) | (1<<DDA3) | (1<<DDA2) | (1<<DDA1) | (1<<DDA0);
// State: Bit7=T Bit6=T Bit5=T Bit4=T Bit3=T Bit2=T Bit1=T Bit0=T
PORTA=(0<<PORTA7) | (0<<PORTA6) | (0<<PORTA5) | (0<<PORTA4) | (0<<PORTA3) | (0<<PORTA2) | (0<<PORTA1) | (0<<PORTA0);
// Port B initialization
// Function: Bit7=In Bit6=In Bit5=In Bit4=In Bit3=In Bit2=In Bit1=In Bit0=In
DDRB=(0<<DDB7) | (0<<DDB6) | (0<<DDB5) | (0<<DDB4) | (0<<DDB3) | (0<<DDB2) | (0<<DDB1) | (0<<DDB0);
PORTB=(0<<PORTB7) | (0<<PORTB6) | (0<<PORTB5) | (0<<PORTB4) | (0<<PORTB3) | (0<<PORTB2) | (0<<PORTB1) | (0<<PORTB0);
// Port C initialization
DDRC=(0<<DDC7) | (0<<DDC6) | (0<<DDC5) | (0<<DDC4) | (0<<DDC3) | (0<<DDC2) | (0<<DDC1) | (0<<DDC0);
PORTC=(0<<PORTC7) | (0<<PORTC6) | (0<<PORTC5) | (0<<PORTC4) | (0<<PORTC3) | (0<<PORTC2) | (0<<PORTC1) | (0<<PORTC0);
// Port D initialization
DDRD=(0<<DDD7) | (0<<DDD6) | (0<<DDD5) | (0<<DDD4) | (0<<DDD3) | (0<<DDD2) | (0<<DDD1) | (0<<DDD0);
PORTD=(0<<PORTD7) | (0<<PORTD6) | (0<<PORTD5) | (0<<PORTD4) | (0<<PORTD3) | (0<<PORTD2) | (0<<PORTD1) | (0<<PORTD0);
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=0xFF
// OC0 output: Disconnected
TCCR0=(0<<WGM00) | (0<<COM01) | (0<<COM00) | (0<<WGM01) | (0<<CS02) | (0<<CS01) | (0<<CS00);
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer1 Stopped
// Mode: Normal top=0xFFFF
// OC1A output: Disconnected
// OC1B output: Disconnected
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=(0<<COM1A1) | (0<<COM1A0) | (0<<COM1B1) | (0<<COM1B0) | (0<<WGM11) | (0<<WGM10);
TCCR1B=(0<<ICNC1) | (0<<ICES1) | (0<<WGM13) | (0<<WGM12) | (0<<CS12) | (0<<CS11) | (0<<CS10);
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer2 Stopped
// OC2 output: Disconnected
ASSR=0<<AS2;
TCCR2=(0<<PWM2) | (0<<COM21) | (0<<COM20) | (0<<CTC2) | (0<<CS22) | (0<<CS21) | (0<<CS20);
TCNT2=0x00;
OCR2=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=(0<<OCIE2) | (0<<TOIE2) | (0<<TICIE1) | (0<<OCIE1A) | (0<<OCIE1B) | (0<<TOIE1) | (0<<OCIE0) | (0<<TOIE0);
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=(0<<ISC11) | (0<<ISC10) | (0<<ISC01) | (0<<ISC00);
MCUCSR=(0<<ISC2);
// USART initialization
// USART disabled
UCSRB=(0<<RXCIE) | (0<<TXCIE) | (0<<UDRIE) | (0<<RXEN) | (0<<TXEN) | (0<<UCSZ2) | (0<<RXB8) | (0<<TXB8);
// Analog Comparator initialization
// Analog Comparator: Off
// The Analog Comparator's positive input is
// connected to the AIN0 pin
// The Analog Comparator's negative input is
// connected to the AIN1 pin
ACSR=(1<<ACD) | (0<<ACBG) | (0<<ACO) | (0<<ACI) | (0<<ACIE) | (0<<ACIC) | (0<<ACIS1) | (0<<ACIS0);
SFIOR=(0<<ACME);
// ADC initialization
// ADC disabled
ADCSRA=(0<<ADEN) | (0<<ADSC) | (0<<ADATE) | (0<<ADIF) | (0<<ADIE) | (0<<ADPS2) | (0<<ADPS1) | (0<<ADPS0);
// SPI initialization
// SPI disabled
SPCR=(0<<SPIE) | (0<<SPE) | (0<<DORD) | (0<<MSTR) | (0<<CPOL) | (0<<CPHA) | (0<<SPR1) | (0<<SPR0);
// TWI initialization
// TWI disabled
TWCR=(0<<TWEA) | (0<<TWSTA) | (0<<TWSTO) | (0<<TWEN) | (0<<TWIE);
// Alphanumeric LCD initialization
// Connections are specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTA Bit 0
// RD - PORTA Bit 1
// EN - PORTA Bit 2
// D4 - PORTA Bit 4
// D5 - PORTA Bit 5
// D6 - PORTA Bit 6
// D7 - PORTA Bit 7
// Characters/line: 20
lcd_init(20);
define_char(newchar1);
while (1)
      for(k=0;k<2;k++)
          for (i=0;i<=7;i++)
              for (j=0;j<=19;j++)
                 lcd_gotoxy(j,k);
                 lcd_putchar(i);
      delay_ms(100);
      for(k=1;k>=0;k--)
          for(i=6;i>=0;i--)
              for(j=19;j>=0;j--)
                  lcd_gotoxy(j,0);
                  lcd_putchar(i);
                  lcd_gotoxy(j,1);
                  lcd_putchar(i);
      delay_ms(100);
You have to set pins connected to LCD as output pins and you have to initialize LCD. If you try to write to LCD without initializing LCD then you get this error in Proteus.
Reactions: FvM
    FvM
Dear Milan.rajik
I did whatever you have said, but the problem not solved,
the hole of my code is below, i think must be something wrong in loops of my code.
Project :
Version :
Date    : 21/05/2014
Author  :
Company :
Comments:
#include <mega32.h>
#include <delay.h>
#include <alcd.h>
int i, a;
a=0x40;
void main(void)
// State: Bit7=0 Bit6=0 Bit5=0 Bit4=0 Bit3=0 Bit2=0 Bit1=0 Bit0=0
TCNT0=0x00;
OCR0=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0<<AS2;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
MCUCSR=(0<<ISC2);
// USART disabled
SFIOR=(0<<ACME);
// ADC disabled
// SPI disabled
// TWI disabled
// RS - PORTA Bit 0
// RD - PORTA Bit 1
// EN - PORTA Bit 2
// D4 - PORTA Bit 4
// D5 - PORTA Bit 5
// D6 - PORTA Bit 6
// D7 - PORTA Bit 7
lcd_init(20);
while (1)
      for(k=0;k<2;k++)
          for (i=0;i<=7;i++)
              for (j=0;j<=19;j++)
                 lcd_gotoxy(j,k);
                 lcd_putchar(i);
      delay_ms(100);
      for(k=1;k>=0;k--)
          for(i=6;i>=0;i--)
              for(j=19;j>=0;j--)
                  lcd_gotoxy(j,k);
                  lcd_putchar(i);
      delay_ms(100);
