I want to use HC-SR04 ultrasonic sensor with a comparator. My goal is so simple. when a object comes in a certain range of the sensor the voltage of the comparator's Non-inverting pin will be higher than the Inverting pic and in output a LED will glowup.
My question is can i deal with echo pin and trigger pin of the sensor
The datasheet for the sensor shows how to trigger it and what its echo is. Its output is a pulse, not continuous.
But the translation from Chinese is a nightmare.
It says, " The Echo is a distance object that is pulse width and the range in proportion" which might be that the duration of the echo pulse is determined by the distance?
