HC-05 bluetooth module communicating wit arduino uno board but not on standalone mode
punithpeshva
Newbie level 1
Newbie level 1
i am communicating easily with arduino uno board with hc05 but when i make it with standalone board atmega 328p its not communicating i have checked the standalone board with other programs and its working good.
The following programis here
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
#include <SoftwareSerial.h>// import the serial library
SoftwareSerial puniBT(10, 11); // RX, TX
int ledpin=13; // led on D13 will show blink on / off
int BluetoothData; // the data given from Computer
void setup() {
  // put your setup code here, to run once:
  puniBT.begin(9600);
  puniBT.println("Bluetooth On please press 1 or 0 blink LED ..");
  pinMode(ledpin,OUTPUT);
void loop() {
  // put your main code here, to run repeatedly:
   if (puniBT.available()){
BluetoothData=puniBT.read();
   if(BluetoothData=='1'){   // if number 1 pressed ....
   digitalWrite(ledpin,1);
   puniBT.println("LED  On D13 ON ! ");
  if (BluetoothData=='0'){// if number 0 pressed ....
  digitalWrite(ledpin,0);
   puniBT.println("LED  On D13 Off ! ");
delay(100);// prepare for next data ...
please help me out.:( :smiley-sad-blue:  :'(
Did you check for a header file that includes the function(s) that end with BT?
Maybe because of that,your system is not working...
And can you explain what does the program do from line(s) 16 to 24?
