[PIC] Hang up on Motor control in pic
Mani Yuvan
Member level 1
Member level 1
Tamilnadu , India
Hang problem on Motor control in pic
i done the wireless control dc motor interface with pic. I check the output in Proteus successfully and also i checked in the real time.it works good but after some time it's not responding the control key example when i pressed forward direction it not responded.after some time gap it respond. i also attach my coding..here....
#include<p18f452.h>
#include"H:\RECovery RObot\header files\motor.h"
#include"H:\RECovery RObot\header files\delay.h"
#include"H:\RECovery RObot\header files\ladder.h"
#pragma config OSC=HS, OSCS=OFF
#pragma config DEBUG=OFF, LVP=OFF, STVR=OFF
#pragma config WDT=OFF
#pragma config BOR=OFF, PWRT=OFF
#define s1 PORTBbits.RB2
#define s2 PORTBbits.RB3
#define s3 PORTBbits.RB4
#define s4 PORTBbits.RB5
void main()
	TRISBbits.TRISB2=1;
	TRISBbits.TRISB3=1;
	TRISBbits.TRISB4=1;
	TRISBbits.TRISB5=1;
	TRISCbits.TRISC0=0;
	TRISCbits.TRISC1=0;
	TRISCbits.TRISC2=0;
	TRISCbits.TRISC3=0;
	TRISCbits.TRISC4=0;
	TRISCbits.TRISC5=0;
ADCON1=0X07;
	TRISAbits.TRISA0=0;
	TRISAbits.TRISA1=0;
	while(1)
if(s1&s3)
ladder_up();
breaks();
	delay(200);
else if(s4&s3)
ladder_down();
breaks();
	delay(200);
else if(s1&s2)
pump_r();
breaks();
	delay(200);
else if(s4&s2)
pump_l();
breaks();
	delay(200);
else if(s1==1)
	stop();
			rotate_f();
			delay(200);
	else if(s2==1)
	stop();
			rotate_r();
	delay(200);
	else if(s3==1)
	stop();
			rotate_l();
	delay(200);
	else if(s4==1)
			stop();
			rotate_b();
	delay(200);//200 ms delay
	else
			breaks();
			stop();
delay(200);
Re: Hang problem on Motor control in pic
Post full code and Zip and post complete MPLAB project files.
As PIC18F is used, use LATxbits.Latxy instead of PORTxbits.Rxy for output pins.
It is answered many times in the forum. Do a search.
