Re: Handover in Wimax
ya you understood correct, but the HO happens with MS due to the loss in Signal strength ( RSSI and CINR values) but the BS can initiate HO due to loss in signal strength and the overloading.
The decision of HO based on overloading, can be taken by only BS.
If MS and BS initiate HO, MS is always given priority to initiate the HO.
well coming to the Point, keeping the overloading aside, if MS is able to initiate the HO based on signal strength then why is BS also initiating HO. is there any significance in it??????
