ge
Full Member level 5
- Joined
- Jun 23, 2006
- Messages
- 251
- Helped
- 29
- Reputation
- 58
- Reaction score
- 29
- Trophy points
- 1,308
- Location
- Pennsylvania, USA
- Activity points
- 2,782
Has anyone seen a performance difference between soldering parts by hand vs epoxy & reflow oven?
I have a board with 2 good SMA connectors and 5 relays. When run thru the reflow oven the insertion loss increases by 2.5dB at 3GHz.
The loss does not appear to be associate with the connectors, relays or thickness of the solder or paste. I've ruled out the connectors and relays by replacing them. I've ruled out solder thickness by adding/wicking off material. The results are repeatable.
Odd epoxy?
thanks,
GE
Odd epoxy?
thanks,
GE
