Half bridge Vs. full bridge
levnu
Full Member level 2
Full Member level 2
Israel
Can someone help by mentioning (summarize) the pros & cons of half/full bridge
(while i'm trying to generate an AC signal on a load by using PWM signal?)
does full bridge allow to generate (work) with more power on the load while using the same DC source? if yes why?
what are the general differences, i tried to find answers on the web but there is no focused summary of it
while watching on both configuratins its seems almost the same with a difference that in half bridge there are capacitores instead of Mosfets, yet isn't the same current goes throw the load on both configurations?
The same current doesn't go thru the load, the applied volts are half for the half bridge, hence the load impedance needs to be 1/2 if you want the same current - i.e. you'll need bigger mosfets for the same power in a half bridge. Also reactive loads behave differently in a half bridge - resulting in driving up the cap voltage for low freq AC into an inductive load...
