H-Bridge Driver With N-Channel MOSFETs/IGBT
mcmsat13
Member level 5
Member level 5
I hope this circuit is ok for uMOS/IGBT H-bridge driver. My device is dual IGBT.
I will be using it to drive 24V and 48V power Inverter.
Please if the Cap for the bootstrap is under/over-ratted, I want to be corrected
Thanks.
Bootstrap capacitors have to be chosen according to maximum pulse width.
For low voltage applications, MOSFETs are usually preferred due to lower saturation voltage.
