cmy1st
Newbie level 3
Hello!!
I have question for H-Bridge diode
This is H-Brige diode
When i design H-Bridge, i know H-Bridge need diode for below reason
" If the switch opens suddenly, then the current wants to go to zero quickly and dI/dt would be a large negative value. Since the motor is an inductor and V=LdI/dt, the voltage across the motor hass a large negative value. we could have voltage spikes. These voltage spikes can cause the switch to arc over and blow up.
The solution to this problem is to putwhat is known as a flyback diode in the reverse direction across the inductive load, so that the voltage spike will forward bias the diode, creating a return path for the current."
But I have ESD diode in chip at H-Bridge diode output pin , this ESD diode has same connection like flyback diode
So, i confuse What differet flyback diode, and ESD..
and I really need flyback diode parallel to ESD
Thanks.
Thanks.
