GeorgesWelding
Member level 3
Now that I seem to have solved my IGBT switching issues I was having in my other thread, still testing though, I've started to design the circuit board for the full version of my H-Bridge. I figured a double sided circuit board would be much better to use than the extremely terrible layout I'm using on my prototype now. I did a little bit of reading about H-Bridge layout and I decided that for me the easiest way to design the board would to put all of the high-power traces on one side, and all of the signal traces on the other. I still have a lot to learn about PCB design so if my thinking is wrong, please correct me on it. Also, is my choice in IGBT going to be ok? I was told these would be find for what I was doing, but if there is a better choice please let me know.
Attached is the PDF of the H-Bridge with 2 paralleled IGBTs making up each switch, the free-wheeling diodes, filter caps, 2 storage caps(2-4 more(if needed) will be mounted off the board as well) and the IGBT drive resistors and diodes. The maroon color is the top copper layer, green is the bottom. I designed this using ExpressPCB. I have a copy of Multisim & Ultiliboard 10 but EPCB's simple interface seemed to be much easier for me being new to PCB design. The IGBTs(IRG4PSC71UDPBF/Super-247 Case) will be mounted on the top of the board with their backs facing up and the heat-sinks will be bolted on top of those. The FW diodes will also be mounted to the top with a tiny heat-sink behind each one(Will that be enough? There will be very good fans attached.) All the other components will be mounted from the bottom. C1 & C2 are 1000uF/400VDC storage caps(Again, 2-4 more of these(if needed) will be mounted off-board but still very close). C3 & C5 are 1uF/400VDC filter caps, and C4 & C6 are 2.2uF filter caps. D9-16 are MUR1560 diodes(My IGBTs are Co-Packed with FW diodes internal to their case as well). The small resistors and diodes are the IGBT drive components. The W# holes are where the input power and output power leads will be bolted to the board and the MT# holes are just mounting points. This board will be mounted bottom-up and the control board that will house the driver ICs will be mounted above this board so the driver leads from the control board to the bridge board shouldn't be more than an inch or so each(I know they all should be the exact same length). I can't think of anything else right now. I'm currently transferring the schematic of this bridge board from paper into the computer, I just drew up the board first as I wanted some insight on it. Thanks in advance for looking. Also, I know some of the green traces are hidden, but it should be pretty obvious where they go, if not I can post up a PDF of just the bottom side of the board.
Also, since I used the ExpressPCB software to design this board, they do offer a service to actually make this board(have to order atleast 2) but has anybody used this service before and how is the quality of their boards? Do you think it would be a good place to have these prototypes made? Their software quoted me $169.95 including shipping for 2 boards.
-Brad
View attachment Bridge Board (Dual IGBT).pdf
-Brad
