Gyrator simulated inductor design?
mr_monster
Member level 4
Member level 4
I would like to make a simulated inductor which is tune-able using an opamp implementation of an opamp. I could find a good source for the design process so anything like that would be greatly appreciated. Thanks!
Falstad's animated simulator includes a gyrator (active inductor) in its menu of circuits.
Screenshot:
Clicking this link will open the falstad.com website, load the above schematic, and run it on your computer. (Click Allow to load the Java applet.)
https://tinyurl.com/axjyjqz
You can change values by right-clicking a component and choosing Edit.
I don't know how to make it tunable.
Screenshot:
Thanks for the link! However I did not see any formulas or anything on there? I would like to know how to set the inductor parameters using part selection... thanks!
Yes, I believe it works like this...
The upper schematic shows 250 nF & 20k (the resistor to ground). The capacitive time constant (R x C) comes out to .005.
The lower schematic shows 5H & 1k. The inductive time constant (L/R) is .005. This matches the upper example as to math and performance.
So for a given capacitor value in the gyrator, you can tune its effective Henry value by adjusting the resistor to ground.
As you will have noted - the circuit as given in post#2 is an active lossy inductor.
In case you need a lossless inductor you must use a GIC implementation using two opamps.
When you say lossless, you mean without series resistance? What would be a Q of such an inductor if that is even discussable in those terms? What about the Q of a simulated inductor? reactance / resistance?
I can make a tunable version by using a variable resistor instead of resistor going to ground?
"Lossless" means: Without resistive losses. Thus, under ideal conditions Q approaching infinity.
In reality - no opamp is ideal and, thus, no GIC implementation is ideal leading to a finite Q - however very large (depending on the opamp type and the operating frequency).
Here is another information which may be helpful for you:
There is another single-opamp active inductor with a parallel loss resistor (instead of a series loss resistor as shown in BradtheRad`s answer).
It is based on the integrator principle. If you are interested - give notice.
Sure I would like to see that!
It`s quite simple:
Take the classical inverting MILLER integrator (R2, C2) and use another resistor R1 between opamp output and signal input (left node of R2).
Then you get an impedance Xp=(Rp||jwL) with Rp=R1||R2 and L=R1*R2*C2.
