thanks,very good guide file.
i install URS5 on RHEL5.4.and it work well.
but there is a problem when i run simulation.the spectre run well,but the wavescan can't work .
and the error information in CIW is"*Error* Failed to launch WaveScan. There is a problem with the DFII installation hierarchy (Exit Code = 214).For further assistance, contact Cadence Customer Support with the diagnostic information available in the log file.You can use AWD as your waveform viewer until the problem is resolved.
*Info* Dumping diagnostic information ...."
i checked the ade_wavescan.log and the hs_error_****.log,it looks like there are JVM errors.
though the wavescan can be replaced by the ADW,i'm afraid wheher the JVM cause other problem.
did you you encounter the same problem?
this is the hs_error_pid3160.log
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0xae3487d6, pid=3160, tid=4160015040
# Java VM: Java HotSpot(TM) Client VM (1.4.2_13-b06 mixed mode)
# Problematic frame:
# C [libwslicense.so+0xb47d6] nnllCu+0xca
--------------- T H R E A D ---------------
Current thread (0x08700718): JavaThread "main" [_thread_in_native, id=3160]
siginfo:si_signo=11, si_errno=0, si_code=1, si_addr=0x00000000
Registers:
EAX=0xffe1f738, EBX=0xae3e16a8, ECX=0xae169000, EDX=0x00000000
ESP=0xffe1f730, EBP=0xffe2035c, ESI=0x00004440, EDI=0xffe240ac
EIP=0xae3487d6, CR2=0x00000000, EFLAGS=0x00010282
Top of Stack: (sp=0xffe1f730)
0xffe1f730: 00000000 ae3e16a8 00000000 00000000
0xffe1f740: 00000000 00000000 00000000 00000000
0xffe1f750: 00000000 00000000 00000000 00000000
0xffe1f760: 00000000 00000000 00000000 00000000
0xffe1f770: 00000000 00000000 00000000 00000000
0xffe1f780: 00000000 00000000 00000000 00000000
0xffe1f790: 00000000 00000000 00000000 00000000
0xffe1f7a0: ffe20a44 ffe240ac ffe203e4 ae3ad43c
Instructions: (pc=0xae3487d6)
0xae3487c6: 00 74 27 8b 45 fc 8b 50 0c 52 8b 45 fc 8b 50 10
0xae3487d6: 8b 02 50 8b 45 f0 83 c0 04 50 e8 1f 3d f6 ff 83
Stack: [0xffc35000,0xffe27000), sp=0xffe1f730, free space=1961k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [libwslicense.so+0x996c0]
C [libwslicense.so+0x9954a] bXF3YF+0x13a
C [libwslicense.so+0xa596f]
C [libwslicense.so+0xa5784] ahAdHL+0x12c
C [libwslicense.so+0xa54d9] fCzBTu+0x139
C [libwslicense.so+0xe9add]
C [libwslicense.so+0xe7cd8]
C [libwslicense.so+0xe72fd] c_2GIW+0x175
C [libwslicense.so+0xe70c3] xcDKeZ+0xa3
C [libwslicense.so+0xdd374] wBX279+0x58a
C [libwslicense.so+0xdda0e] uWIidt+0x5b
C [libwslicense.so+0xde67e] uhY9K6+0x119
C [libwslicense.so+0x1986c] Java_COM_cadence_awd_license_License_checkLicense+0x4c
j COM.cadence.awd.license.License.checkLicense(Ljava/lang/String;D)Z+0
j COM.cadence.awd.license.License.doLicenseCheck([Ljava/lang/String;[LCOM/cadence/awd/license/Product
Z+32
j COM.cadence.awd.session.ApplicationManager.main([Ljava/lang/String
V+346
v ~StubRoutines::call_stub
V [libjvm.so+0x1af5c4]
V [libjvm.so+0x265049]
V [libjvm.so+0x1af816]
V [libjvm.so+0x1b7ade]
V [libjvm.so+0x1c66ad]
C [java+0x1880]
C [libc.so.6+0x15e9c] __libc_start_main+0xdc
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
Z+32
V+346
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0xb01044a0 JavaThread "CompilerThread0" daemon [_thread_blocked, id=3166]
0xb01036a0 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=3165]
0xb0100568 JavaThread "Finalizer" daemon [_thread_blocked, id=3163]
0x08735eb0 JavaThread "Reference Handler" daemon [_thread_blocked, id=3162]
=>0x08700718 JavaThread "main" [_thread_in_native, id=3160]
Other Threads:
0x08734c00 VMThread [id=3161]
0xb0105fe8 WatcherThread [id=3167]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 11072K, used 783K [0xb0c00000, 0xb1800000, 0xb5ac0000)
eden space 9856K, 7% used [0xb0c00000, 0xb0cc3d18, 0xb15a0000)
from space 1216K, 0% used [0xb15a0000, 0xb15a0000, 0xb16d0000)
to space 1216K, 0% used [0xb16d0000, 0xb16d0000, 0xb1800000)
tenured generation total 24576K, used 0K [0xb5ac0000, 0xb72c0000, 0xf0c00000)
the space 24576K, 0% used [0xb5ac0000, 0xb5ac0000, 0xb5ac0200, 0xb72c0000)
compacting perm gen total 24576K, used 1949K [0xf0c00000, 0xf2400000, 0xf3c00000)
the space 24576K, 7% used [0xf0c00000, 0xf0de74b0, 0xf0de7600, 0xf2400000)
Dynamic libraries:
0071d000-00737000 r-xp 00000000 08:01 10388556 /lib/ld-2.5.so
00737000-00738000 r-xp 00019000 08:01 10388556 /lib/ld-2.5.so
00738000-00739000 rwxp 0001a000 08:01 10388556 /lib/ld-2.5.so
0073b000-0087a000 r-xp 00000000 08:01 10387473 /lib/libc-2.5.so
0087a000-0087b000 ---p 0013f000 08:01 10387473 /lib/libc-2.5.so
0087b000-0087d000 r-xp 0013f000 08:01 10387473 /lib/libc-2.5.so
0087d000-0087e000 rwxp 00141000 08:01 10387473 /lib/libc-2.5.so
0087e000-00881000 rwxp 0087e000 00:00 0
00883000-00896000 r-xp 00000000 08:01 10387536 /lib/libpthread-2.5.so
00896000-00897000 r-xp 00013000 08:01 10387536 /lib/libpthread-2.5.so
00897000-00898000 rwxp 00014000 08:01 10387536 /lib/libpthread-2.5.so
00898000-0089a000 rwxp 00898000 00:00 0
0089c000-008c1000 r-xp 00000000 08:01 10387480 /lib/libm-2.5.so
008c1000-008c2000 r-xp 00024000 08:01 10387480 /lib/libm-2.5.so
008c2000-008c3000 rwxp 00025000 08:01 10387480 /lib/libm-2.5.so
008c5000-008c7000 r-xp 00000000 08:01 10387488 /lib/libdl-2.5.so
008c7000-008c8000 r-xp 00001000 08:01 10387488 /lib/libdl-2.5.so
008c8000-008c9000 rwxp 00002000 08:01 10387488 /lib/libdl-2.5.so
00c37000-00c4a000 r-xp 00000000 08:01 10387459 /lib/libnsl-2.5.so
00c4a000-00c4b000 r-xp 00012000 08:01 10387459 /lib/libnsl-2.5.so
00c4b000-00c4c000 rwxp 00013000 08:01 10387459 /lib/libnsl-2.5.so
00c4c000-00c4e000 rwxp 00c4c000 00:00 0
08048000-08053000 r-xp 00000000 00:1a 9734223 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/bin/java
08053000-08055000 rwxp 0000a000 00:1a 9734223 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/bin/java
086fd000-08791000 rwxp 086fd000 00:00 0 [heap]
ae169000-ae19e000 r-xs 00000000 08:01 4654231 /var/db/nscd/hosts
ae19e000-ae1ab000 r-xp 00000000 00:1a 8609832 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/lib/libcls_sh.so
ae1ab000-ae1ac000 rwxp 0000d000 00:1a 8609832 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/lib/libcls_sh.so
ae1ac000-ae246000 r-xp 00000000 00:1a 9013052 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/lib/libstdc++.so.5.0.3
ae246000-ae25b000 rwxp 00099000 00:1a 9013052 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/lib/libstdc++.so.5.0.3
ae25b000-ae260000 rwxp ae25b000 00:00 0
ae260000-ae26f000 r-xp 00000000 00:1a 9189007 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/lib/libcdsCommon_sh.so
ae26f000-ae270000 rwxp 0000e000 00:1a 9189007 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/lib/libcdsCommon_sh.so
ae270000-ae274000 rwxp ae270000 00:00 0
ae274000-ae28f000 r-xp 00000000 00:1a 5508339 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/lib/libvirtuos_sh.so
ae28f000-ae291000 rwxp 0001a000 00:1a 5508339 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/lib/libvirtuos_sh.so
ae291000-ae294000 rwxp ae291000 00:00 0
ae294000-ae3d6000 r-xp 00000000 00:1a 10058821 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/dfII/lib/libwslicense.so
ae3d6000-ae3e3000 rwxp 00142000 00:1a 10058821 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/dfII/lib/libwslicense.so
ae3e3000-ae403000 rwxp ae3e3000 00:00 0
ae403000-ae435000 r-xs 00000000 00:1a 9705709 /storage/eda/eda_software/Cadence/IC51/share/java/jai-1_1_1_01/lib/jai_codec.jar
ae435000-ae43c000 r-xs 00000000 00:1a 3177657 /storage/eda/eda_software/Cadence/IC51/share/java/jaxp.jar
ae43c000-ae46a000 r-xs 00000000 00:1a 9705716 /storage/eda/eda_software/Cadence/IC51/share/java/crimson.jar
ae46a000-ae4d8000 r-xs 00000000 00:1a 9705698 /storage/eda/eda_software/Cadence/IC51/share/java/symphony.jar
ae4d8000-ae51d000 r-xs 00000000 00:1a 9705700 /storage/eda/eda_software/Cadence/IC51/share/java/wsutil.jar
ae51d000-ae740000 r-xs 00000000 00:1a 9705699 /storage/eda/eda_software/Cadence/IC51/share/java/wavescan.jar
ae740000-ae7fb000 r-xs 00000000 00:1a 5566411 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/ext/localedata.jar
ae7fb000-ae7fc000 ---p ae7fb000 00:00 0
ae7fc000-aecfc000 rwxp ae7fc000 00:00 0
aecfc000-aecfd000 ---p aecfc000 00:00 0
aecfd000-aed0a000 rwxp aecfd000 00:00 0
aed0a000-aed0d000 ---p aed0a000 00:00 0
aed0d000-af1fd000 rwxp aed0d000 00:00 0
af1fd000-af1fe000 ---p af1fd000 00:00 0
af1fe000-af20b000 rwxp af1fe000 00:00 0
af20b000-af20e000 ---p af20b000 00:00 0
af20e000-af6fe000 rwxp af20e000 00:00 0
af6fe000-af6ff000 ---p af6fe000 00:00 0
af6ff000-afbff000 rwxp af6ff000 00:00 0
afbff000-afc00000 ---p afbff000 00:00 0
afc00000-afc0d000 rwxp afc00000 00:00 0
afc0d000-afc10000 ---p afc0d000 00:00 0
afc10000-b019a000 rwxp afc10000 00:00 0
b019a000-b0200000 ---p b019a000 00:00 0
b0209000-b0210000 r-xp 00000000 00:1a 9013046 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/lib/libgcc_s.so.1
b0210000-b0211000 rwxp 00007000 00:1a 9013046 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/lib/libgcc_s.so.1
b0211000-b0212000 r-xp 00000000 00:1a 8609834 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/lib/libfastt_sh.so
b0212000-b0213000 rwxp 00000000 00:1a 8609834 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/lib/libfastt_sh.so
b0213000-b0221000 r-xs 00000000 00:1a 9705696 /storage/eda/eda_software/Cadence/IC51/share/java/cds_srr.jar
b0221000-b024a000 r-xs 00000000 00:1a 9705697 /storage/eda/eda_software/Cadence/IC51/share/java/srr.jar
b024a000-b0257000 r-xs 00000000 00:1a 5566410 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/ext/ldapsec.jar
b0257000-b0273000 r-xs 00000000 00:1a 5566408 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/ext/sunjce_provider.jar
b0273000-b0274000 ---p b0273000 00:00 0
b0274000-b0281000 rwxp b0274000 00:00 0
b0281000-b0284000 ---p b0281000 00:00 0
b0284000-b0774000 rwxp b0284000 00:00 0
b0774000-b0775000 ---p b0774000 00:00 0
b0775000-b0802000 rwxp b0775000 00:00 0
b0802000-b080e000 rwxp b0802000 00:00 0
b080e000-b081b000 rwxp b080e000 00:00 0
b081b000-b09e7000 rwxp b081b000 00:00 0
b09e7000-b09ed000 rwxp b09e7000 00:00 0
b09ed000-b0a0e000 rwxp b09ed000 00:00 0
b0a0e000-b0a1b000 rwxp b0a0e000 00:00 0
b0a1b000-b0be7000 rwxp b0a1b000 00:00 0
b0be7000-b0bf3000 rwxp b0be7000 00:00 0
b0bf3000-b0bff000 rwxp b0bf3000 00:00 0
b0bff000-b1800000 rwxp b0bff000 00:00 0
b1800000-b5ac0000 rwxp b1800000 00:00 0
b5ac0000-b72c0000 rwxp b5ac0000 00:00 0
b72c0000-f0c00000 rwxp b72c0000 00:00 0
f0c00000-f2400000 rwxp f0c00000 00:00 0
f2400000-f3c00000 rwxp f2400000 00:00 0
f3c01000-f3c2c000 rwxp f3c01000 00:00 0
f3c2c000-f3ca9000 rwxp f3c2c000 00:00 0
f3ca9000-f3d31000 rwxp f3ca9000 00:00 0
f3d31000-f5ca9000 rwxp f3d31000 00:00 0
f5ca9000-f626d000 r-xs 00000000 00:1a 8942899 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/charsets.jar
f626d000-f627f000 r-xs 00000000 00:1a 5566413 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/jce.jar
f627f000-f6359000 r-xs 00000000 00:1a 8942898 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/jsse.jar
f6359000-f636f000 r-xs 00000000 00:1a 5566412 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/sunrsasign.jar
f636f000-f63b9000 rwxp f636f000 00:00 0
f63b9000-f7aaa000 r-xs 00000000 00:1a 9879755 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/rt.jar
f7aaa000-f7ab8000 r-xp 00000000 00:1a 8253964 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/i386/libzip.so
f7ab8000-f7aba000 rwxp 0000d000 00:1a 8253964 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/i386/libzip.so
f7aba000-f7ac7000 r-xp 00000000 00:1a 8253961 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/i386/libverify.so
f7ac7000-f7ac9000 rwxp 0000c000 00:1a 8253961 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/i386/libverify.so
f7ac9000-f7acd000 rwxs 00000000 08:01 7012456 /tmp/hsperfdata_chenw/3160
f7acd000-f7b02000 r-xs 00000000 08:01 4654079 /var/db/nscd/passwd
f7b02000-f7f1b000 r-xp 00000000 00:1a 8253955 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/i386/client/libjvm.so
f7f1b000-f7f37000 rwxp 00418000 00:1a 8253955 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/i386/client/libjvm.so
f7f37000-f7f4d000 rwxp f7f37000 00:00 0
f7f4d000-f7f50000 r-xs 00000000 00:1a 5566409 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/ext/dnsns.jar
f7f50000-f7f6c000 r-xp 00000000 00:1a 8253962 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/i386/libjava.so
f7f6c000-f7f6e000 rwxp 0001b000 00:1a 8253962 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/i386/libjava.so
f7f6e000-f7f74000 r-xp 00000000 00:1a 8253949 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/i386/native_threads/libhpi.so
f7f74000-f7f76000 rwxp 00005000 00:1a 8253949 /storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/i386/native_threads/libhpi.so
f7f76000-f7f77000 rwxp f7f76000 00:00 0
ffc2b000-ffc35000 rwxp ffc2b000 00:00 0
ffc35000-ffc38000 ---p ffc35000 00:00 0
ffe14000-ffe2a000 rwxp 7ffffffe9000 00:00 0 [stack]
ffffe000-fffff000 r-xp ffffe000 00:00 0
VM Arguments:
jvm_args: -Dclient.xserver.version=70101000 -Dclient.xserver.vendor=The -Xss5M -Xms36M -Xmx1024M -XX
ermSize=24M -XX:MaxPermSize=48M -XX:NewSize=12M -Dswing.metalTheme=steel
java_command: COM.cadence.awd.session.ApplicationManager -log ade_wavescan.log -noui -exprlang Skill -mpssession icfb3096 -mpshost dell17
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=
PATH=/storage/eda/eda_software/Cadence/IC51/tools/dfII/bin:/storage/eda/eda_software/Cadence/IC51/tools/bin:/storage/eda/eda_software/Cadence/IC51/tools/bin:/storage/eda/eda_software/Cadence/IC51/tools/dfII/bin:/storage/eda/eda_software/Cadence/IC51/tools/spectre/bin:/storage/eda/eda_software/Cadence/IC51/tools/bin:/storage/eda/eda_software/Cadence/IC51/tools/dfII/bin:/storage/eda/eda_software/Cadence/IC51/tools/spectre/bin:/bin:/usr/local/bin:/usr/bin:/usr/X11R6/bin
LD_LIBRARY_PATH=/storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/i386/client:/storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/lib/i386:/storage/eda/eda_software/Cadence/IC51/tools.lnx86/jre1.42/../lib/i386:/storage/eda/eda_software/Cadence/IC51/share/java/COM/cadence/awd/skill/cmdlang/il:/storage/eda/eda_software/Cadence/IC51/tools/dfII/lib:/storage/eda/eda_software/Cadence/IC51/tools/mdl/lib:/storage/eda/eda_software/Cadence/IC51/tools/mdl/expr/lib:/storage/eda/eda_software/Cadence/IC51/tools/lib:/storage/eda/eda_software/Cadence/IC51
SHELL=/bin/bash
DISPLAY=:47.0
--------------- S Y S T E M ---------------
OS:Red Hat Enterprise Linux Server release 5.4 (Tikanga)
uname:Linux 2.6.18-164.el5 #1 SMP Tue Aug 18 15:51:48 EDT 2009 x86_64
libc:glibc 2.5 NPTL 2.5
rlimit: STACK 10240k, CORE 0k, NPROC 530432, NOFILE 4096, AS infinity
load average:0.00 260219922383576036862578459456996855110087202094675779320111609847027197739141528563827846854106925071208633362123537247019903127485925331743249756813588943246021192325855742394915209016510236299214591618973696.00 177842483722168517742098732790950687621750830720695060824467715489357813427131576483511674471100065829529060399307305199073232163973417691407997097213739181669173474762977596247552173167944648915404311788509987144385540434647742189258045934019178159691095681642911858950144.00
CPU:total 24 family 6, cmov, cx8, fxsr, mmx, sse, sse2
Memory: 4k page, physical 16113k(41k free), swap 0k(0k free)
vm_info: Java HotSpot(TM) Client VM (1.4.2_13-b06) for linux-x86, built on Oct 18 2006 10:27:30 by unknown with unknown compiler
