GSM security system using pic18f4620
ralphbanque
Newbie level 3
Newbie level 3
hello guys,
I am trying to make a project that sends a message to a cellphone number when a door or window is opened.
I am using pic18f4620 and sim500w GSM module.
When i run it on simulation it's ok but on the actual hardware it doesn't work, it becomes stuck at the first part of the program.
Please help and thanks in advance
you should provide your mcu code and hardware diagram.
that could be helpful for you
hello guys,
First of all find out that it is software problem or hardware.
1) use delays in your code.
2) use rs232 or lcd or any thing else and send current status of micro-controller on lcd or rs232.
3) connect noise filters in your micro-controller power supply and make shore that microcontroller is running on +5v.
Post the datasheet of SIM500w. How did you simulate GSM in proteus. Do you have GSM module in proteus or did you just check the serial communication in Proteus? Post you code so that we can see what is the first part of the program.
hello guys,
here are the datasheets of sim500w one is for the hardware and the other is for the software...
in simulating the GSM we used DCU-11 cable and connected it via COMPIM
here is my code :
void keypadString(int delimeter,int max,int start);
void inputPin(int delimeter,int max,int start);
char ascii(int key);
void Register();
void Sensor();
void GSM_init();
void sendSMS(char dest[15], char mess[200]);
void getData();
void check();
short newMess();
void checkGSM(short index);
short reg_num=0,reg_ans=0,arm_disarm=1;
char str[30]="", number[11]="", number2[11]="", pin1[4]="", pin2[4]="",spin[4]="",comm[3]="", *data="", *smes="";
char sender[20]=" ", mes[20]=" ";
short newMess()
short cnt=0,retval=0;
char *rep="",ch=' ';
while(1)
if(Usart_Data_Ready())
ch=Usart_Read();
rep[cnt]=ch;
rep[cnt+1]=0;
cnt++;
if(strstr(rep,"+CMTI:")!=0){retval=rep[12]; break;}
else{retval=0;break;}
}return retval;
void gsmON()
short cnt=0, OKflag=0;
Usart_Init(57600);
while(1)
if(OKflag!=0) {PORTE.F1=1;break;}
else {Usart_Write('A');Usart_Write('T');Usart_Write(13);}
while(1)
ch=Usart_Read();
rep[cnt]=ch;
rep[cnt+1]=0;
cnt++;
if(strstr(rep,"OK")!=0) {OKflag=1; delay_ms(300); break;}
else {PORTE.F0=1; delay_ms(3000); PORTE.F0=0;}
void GSM_init()
short cntr=0,a,at=0,OKflag=0;
char ch=' ',ch2=' ',*rep1=" ",*rep2=" ";
gsmON();
OKflag=0;cntr=0;
while(1)
if(OKflag!=0) break;
else {Usart_Write('A');Usart_Write('T');Usart_Write('+');Usart_Write('C');Usart_Write('M');
Usart_Write('G');Usart_Write('F');Usart_Write('=');Usart_Write('1');Usart_Write(13);}
while(1)
ch=Usart_Read();
rep1[cntr]=ch;
rep1[cntr+1]=0;
cntr++;
if(strstr(rep1,"OK")!=0) {OKflag=1; delay_ms(300); break;}
OKflag=0;cntr=0;
while(1)
else {Usart_Write('A');Usart_Write('T');Usart_Write('+');Usart_Write('C');Usart_Write('P');
Usart_Write('M');Usart_Write('S');Usart_Write('=');Usart_Write('"');Usart_Write('s');Usart_Write('m');Usart_Write('"');Usart_Write(13);}
while(1)
ch=Usart_Read();
rep1[cntr]=ch;
rep1[cntr+1]=0;
cntr++;
char ascii(int key) {
switch(key) {
case 0: break;
case 1: return '1'; break;
case 2: return '2'; break;
case 3: return '3'; break;
case 5: return '4'; break;
case 6: return '5'; break;
case 7: return '6'; break;
case 9: return '7'; break;
case 10: return '8'; break;
case 11: return '9'; break;
case 13: break;
case 14: return '0'; break;
case 15: break;
int key=0,cntr=0,S=start,i,j;
char ch=' ';
lcd_custom_out(1,1,"Input pin: ") ;
Lcd_Custom_Cmd(LCD_SECOND_ROW);
while(key != delimeter) {
key = keypad_released();
if(key!=0 && key!=delimeter && key!=13 && cntr<max)
ch = ascii(key);
// str = ch;
Eeprom_Write(S,ch); delay_ms(100);
Lcd_Custom_chr_cp(Eeprom_Read(S));
cntr++; S++;
if(key==13)
LCD_Custom_Cmd(LCD_MOVE_CURSOR_LEFT);
Lcd_Custom_chr_cp(' ');
cntr--; S--;
if(key==delimeter)
if(cntr==max)
if(start==0x0b)
for(i=0,j=start;i<max;i++,j++)
pin1 = Eeprom_Read(j);
Lcd_Custom_Cmd(Lcd_Clear);
Lcd_Custom_Out(1, 1, "PinRegistered:");
Lcd_Custom_Out(2, 1, pin1);
delay_ms(1000);
else if(start==0x1b)
pin2 = Eeprom_Read(j);
Lcd_Custom_Out(1, 1, "PinRegistered::");
Lcd_Custom_Out(2, 1, pin2);
delay_ms(1000);
else
{ Lcd_Custom_Cmd(Lcd_Clear);
Lcd_Custom_Out(1, 1, "Invalid Input");
cntr=0; key=0; S=start; delay_ms(1000);
lcd_custom_out(1,1,"Input Pin: ") ;
void keypadString(int delimeter,int max,int start) {
char ch=' ';
lcd_custom_out(1,1,"Input Number: ") ;
ch = ascii(key);
// str = ch;
cntr++; S++;
if(key==13)
cntr--; S--;
if(key==delimeter)
if(cntr==max)
if(start==0x00)
number = Eeprom_Read(j);
Lcd_Custom_Out(1, 1, "NumberRegistered:");
Lcd_Custom_Out(2, 1, number);
delay_ms(1000);
else if(start==0x10)
number2 = Eeprom_Read(j);
Lcd_Custom_Out(2, 1, number2);
delay_ms(1000);
inputPin(15,4,start+0x0b);
else
void Register()
int key=0,no1=0,ovr=0;
if(reg_num==0)
keypadString(15,11,0x00);
reg_num++;
delay_ms(1000);
else if(reg_num==1)
Lcd_Custom_Out(1, 1, "Add new number?");
Lcd_Custom_Out(2, 1, "(*=yes/#=no)");
delay_ms(500);
while(key!=13 && no1!=1)
key= keypad_released();
if(key==13)
key=0;
keypadString(15,11,0x10);
reg_num++;
delay_ms(1000);
else if(key==15)
{no1=1;reg_ans=1;}
else if(reg_num==2)
Lcd_Custom_Out(1, 1, "Overwrite a number?");
delay_ms(500);
if(key==13)
key=0;
Lcd_Custom_Cmd(Lcd_Clear);Lcd_Custom_Out(1, 1, number);Lcd_Custom_Out(2, 1,number2);
delay_ms(3000);
Lcd_Custom_Out(1, 1, "Choose number");Lcd_Custom_Out(2, 1,"(*=1st/#=2nd)");
key=keypad_released();
while(ovr!=1)
if(key==13)
reg_num++;ovr=1;
delay_ms(1000);
else if(key==15)
keypadString(15,11,0x0f);
reg_num++;ovr=1;
delay_ms(1000);
else if(key==15)
{no1=1;reg_ans=1;}
void Sensor()
if(arm_disarm==1)
lcd_custom_out(1,1,"System Armed") ;
if(PORTB.F0==1)
sendSMS(number,"Sensor 1 is Tripped");delay_ms(2000);
if(reg_num==2)
sendSMS(number2,"Sensor 1 is Tripped");delay_ms(50);
if(PORTB.F1==1)
sendSMS(number,"Sensor 2 is Tripped");delay_ms(2000);
if(reg_num==2)
sendSMS(number2,"Sensor 2 is Tripped");delay_ms(50);
if(PORTB.F2==1)
sendSMS(number,"Sensor 3 is Tripped");delay_ms(2000);
if(reg_num==2)
sendSMS(number2,"Sensor 3 is Tripped");delay_ms(50);
if(PORTB.F3==1)
sendSMS(number,"Sensor 4 is Tripped");delay_ms(2000);
if(reg_num==2)
sendSMS(number2,"Sensor 4 is Tripped");delay_ms(50);
if(PORTB.F4==1)
sendSMS(number,"Sensor 5 is Tripped");delay_ms(2000);
if(reg_num==2)
sendSMS(number2,"Sensor 5 is Tripped");delay_ms(50);
else
lcd_custom_out(1,1,"System Disarmed") ;
delay_ms(500);
char data[15] = " ";
int aCntr=0,cntr=0, a=0, start=0, end=0, b=0, cmgr=0;
int cQntr=0,cQntr2=0, num_start=0,num_end=0,mes_start=0,mes_end=0;
char ch = ' ', gprmc[100]=" ";char gsmData[50]=" ";
// char sender[20]=" ", mes[20]=" ";
TRISB=0x00;
ADCON1=0x0F;
PORTB=0x01;
delay_ms(100);
Usart_Write('A');Usart_Write('T');Usart_Write('+');Usart_Write('C');Usart_Write('M');Usart_Write('G');Usart_Write('R');Usart_Write('=');Usart_Write(index+48);Usart_Write(13);
while(1)
if(aCntr==8){break;}
else{
ch = Usart_Read();
gsmData[cntr] = ch;
gsmData[cntr+1] = 0;
}cntr++;
if(ch=='"') { aCntr++; }
if(strstr(gsmData,number)!=0)
if(strstr(gsmData,pin1)!=0)
if(strstr(gsmData,"arm")!=0)
if(arm_disarm==1)
{sendSMS(number,"Already Armed");}
else {sendSMS(number,"System Armed");arm_disarm=1;}
else if(strstr(gsmData,"dis")!=0)
if(arm_disarm==0)
{sendSMS(number,"Already Disarmed");}
else {sendSMS(number,"System Armed");arm_disarm=0;}
else
{sendSMS(number,"Wrong PIN");}
else if(strstr(gsmData,number2)!=0)
if(strstr(gsmData,pin2)!=0)
if(arm_disarm==1)
{sendSMS(number2,"Already Armed");}
else {sendSMS(number2,"System Armed");arm_disarm=1;}
if(arm_disarm==0)
{sendSMS(number2,"Already Disarmed");}
else {sendSMS(number2,"System Armed");arm_disarm=0;}
else
{sendSMS(number2,"Wrong PIN");}
int a=0;
Usart_Write('A');
Usart_Write('T');
Usart_Write('+');
Usart_Write('C');
Usart_Write('M');
Usart_Write('G');
Usart_Write('S');
Usart_Write('=');
Usart_Write('"');
for(a=0;a<11;a++) { delay_ms(100); Usart_Write(dest[a]); }
Usart_Write('"');
Usart_Write(13);delay_ms(10);
for(a=0;a<strlen(mess);a++) { delay_ms(100); Usart_Write(mess[a]); }
delay_ms(1000);
Usart_Write(26);Usart_Write(13);
delay_ms(15000);
void main() {
ADCON1=0x0F;
TRISB=0xff;
PORTB=0x00;
Lcd_Custom_Config(&PORTA,3,2,1,0,&PORTE,1,0,2);
Lcd_Custom_Cmd(Lcd_CURSOR_OFF);
delay_ms(1000);
Lcd_Custom_Out(1, 4, "GSM-Based"); Lcd_Custom_Out(2, 1, "Security System");
delay_ms(3000);Lcd_Custom_Cmd(Lcd_Clear);
Keypad_Init(&PORTD);
Lcd_Custom_Out(1, 4, "Initializing");
GSM_init();//GSM_init();
while(reg_ans==0)
{Register();}
while(1)
//if("new message")
Sensor();
if(newMess())
checkGSM(newMess());
//checkGSM();
//else
delay_ms(10);
hello guys,
here is my code :
void Register();
void Sensor();
void GSM_init();
void getData();
void check();
short newMess();
short newMess()
while(1)
ch=Usart_Read();
rep[cnt]=ch;
rep[cnt+1]=0;
cnt++;
}return retval;
void gsmON()
Usart_Init(57600);
while(1)
while(1)
ch=Usart_Read();
rep[cnt]=ch;
rep[cnt+1]=0;
cnt++;
void GSM_init()
gsmON();
OKflag=0;cntr=0;
while(1)
while(1)
ch=Usart_Read();
rep1[cntr]=ch;
rep1[cntr+1]=0;
cntr++;
OKflag=0;cntr=0;
while(1)
while(1)
ch=Usart_Read();
rep1[cntr]=ch;
rep1[cntr+1]=0;
cntr++;
switch(key) {
case 0: break;
case 13: break;
case 15: break;
char ch=' ';
ch = ascii(key);
// str = ch;
cntr++; S++;
if(key==13)
cntr--; S--;
if(key==delimeter)
if(cntr==max)
if(start==0x0b)
delay_ms(1000);
delay_ms(1000);
else
char ch=' ';
ch = ascii(key);
// str = ch;
cntr++; S++;
if(key==13)
cntr--; S--;
if(key==delimeter)
if(cntr==max)
if(start==0x00)
delay_ms(1000);
delay_ms(1000);
else
void Register()
if(reg_num==0)
reg_num++;
delay_ms(1000);
else if(reg_num==1)
delay_ms(500);
if(key==13)
key=0;
reg_num++;
delay_ms(1000);
else if(key==15)
{no1=1;reg_ans=1;}
else if(reg_num==2)
delay_ms(500);
if(key==13)
key=0;
delay_ms(3000);
while(ovr!=1)
if(key==13)
reg_num++;ovr=1;
delay_ms(1000);
else if(key==15)
reg_num++;ovr=1;
delay_ms(1000);
else if(key==15)
{no1=1;reg_ans=1;}
void Sensor()
if(arm_disarm==1)
if(PORTB.F0==1)
if(reg_num==2)
if(PORTB.F1==1)
if(reg_num==2)
if(PORTB.F2==1)
if(reg_num==2)
if(PORTB.F3==1)
if(reg_num==2)
if(PORTB.F4==1)
if(reg_num==2)
else
delay_ms(500);
TRISB=0x00;
ADCON1=0x0F;
PORTB=0x01;
delay_ms(100);
while(1)
else{
ch = Usart_Read();
gsmData[cntr] = ch;
}cntr++;
if(arm_disarm==1)
if(arm_disarm==0)
else
if(arm_disarm==1)
if(arm_disarm==0)
else
int a=0;
Usart_Write('A');
Usart_Write('T');
Usart_Write('+');
Usart_Write('C');
Usart_Write('M');
Usart_Write('G');
Usart_Write('S');
Usart_Write('=');
Usart_Write('"');
Usart_Write('"');
delay_ms(1000);
delay_ms(15000);
void main() {
ADCON1=0x0F;
TRISB=0xff;
PORTB=0x00;
delay_ms(1000);
while(reg_ans==0)
{Register();}
while(1)
//if("new message")
Sensor();
if(newMess())
//checkGSM();
//else
delay_ms(10);
  • SIM500W&SIM540W_HD_V1.01.pdf
  • SIM500W_ATC_V1.00.pdf
