GSM and GPS integration for PIC16F877A
karthikeie
Hi there,
I am doing my project in vehicle tracking, which uses gps and gsm. I am using pic16f877a(MPLab HItech C compiler). I have completed the codings for both gsm and gps seperately. I need to integrate these things to vehicle tracking. But the pic16f877a has one UART port. Hence suggest me whether i have to use relays to switch between gps, gsm or some other way?
Thanks in advance.Please find the attachments of gps and gsm codings...
  • GSM_msg_send and receive_final.rar
  • PIC UART Code.rar
I will suggest you a simple method which I have implemented. Since you need only to receive data form gps modem connect rx and ground to gps.
If you don't want to get any response form gsm you can connect tx pin and ground to gsm.
I guess you are getting value from gps and sending it through sms.
The only disadvantage is that you cannot read the message from gsm and cannot get the response form gsm.
You can do this by Connecting GPS Trans pin to Controller Receive, and GSM Receive Pin to controller Transmit pin.
But in this you will not check the returns from the GSM Modem.
So my suggestion is to use a Digital Multiplexer i had used two mux one for Transmit Line and One for Receive line to interface three UART Devices, of which one is GSM/GPRS Modem, One is GPS and one is 232 Based Wind Sensor.
You you can easily do this,
Just keep the multiplexer on GPS and when you need send the sms change the mux to GSM and then back to GPS
you could also choose controller with two uart interface ,8051 from dallas has two uart,
