I m using a +15V supply for two applications. the +15v is generated from a single supply. I need to isolate the +15V suppy grounds for the two applications. Is it possible to isolate using opto couplers...
If you need to isolate two circuits you not only have to isolate grounds but +15V, too ..
Depending on power requirements you may consider 1W, 2W or as needed, miniature dc-dc converters .. Input:12-15V .. Output:15V ..
