Ground filling - two layer PCB
kishor jadhav
Member level 1
Pune, Maharashtra, India
ground filling
HI i am route one board (double layer). I was fill ground in both top & bottom layer, create a gerber file but i am not able to see the top layer ground filing was not in gerber file. so how can i fill the ground in both layer & see the gerber file. please help me. I am using OrCAD 9.0.
Thanks In Advance,
Kishor
chakravarthy80pcb
Member level 3
chennai
pcb ground filling
select the obstacle tool and click on the board outline,select copper pour and the Layer(top or bottom) and also select the net name (gnd or vcc).try it it will work out.
hope this will solve your problem
kishor jadhav
Member level 1
Re: Ground filling
Thanks Chakravarty this was work effectively & helpful but still i am having problem. I was fill ground in both layer & create a gerber. In a gerber i have see the top layer is not filling ground only bottom layer was see. so please let us know my problem & solve it.
Thanks In Advance,
Kishor
chakravarthy80pcb
Member level 3
chennai
Ground filling
then you have to check the gerber while creating,select the Top layer (YES) and generate gerbr. the problem is in selecting the layers in postprocessing.
kishor jadhav
Member level 1
Re: Ground filling
ya i was see the postprocess setting top layer was "yes". still i was seen the only component not to see the ground fill in empty space.
