Hello,
First off, I am not an electronics guy, and that is why I am here. My situation: I have a car with no aux input. I just got an Ipod Classic for Christmas. I don't want to lay money into hardwiring an aux or using an FM modulator at the antenna input (I might have this car for three more months). I also don't want to waste money on an FM transmitter, because I understand they don't work well since the FCC cracked down on them in 2006. What I do have is an old Starmate ST2 radio that has a transmitter that predates the change, and it worked really well. Unfortunately, it doesn't have an input plug. What I am looking for: Using an old set of earphones with the ends cut off, is there a place where I could solder the two wires that would channel the input directly to the transmitter? See attached picture. Two boards in a sandwich configuration, with the Sirius antenna input on one, and all of the outputs on the other. The transmitter antenna was soldered to the second board, and consists of a copper wire running the inside perimeter of the case. Does anyone know how I can get the Ipod to play through this? I was thinking that the tuner part of the radio needs to be bypassed, right? I'm just interested in seeing if this could be done.
Thanks,
Mike
