AssemblyLine
Member level 1
Hello
Consider the application of a microinverter with input from solar panel 20-45 V dc (or similar) and output 230V ac into the grid, power 300-500 W. MPPT feature also needed.
Do you know any 100% analog solution, without involving microcontrollers?
the ideal solution would be a single IC to control both stages, but I believe the disadvantages would overcome the benefits, so a two IC solution is also good.
For the DC-DC stage, I know a couple ICs (mostly for LLC topology), but for the dc-ac stage, I do not know.
So is there any IC that can control a MOSFET-full bridge to output a sine wave and have output voltage regulation ?
