giszo
Newbie level 5
- Joined
- Jan 1, 2015
- Messages
- 9
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Location
- Hungary
- Activity points
- 73
I have a project where a switching regulator is used to provided the main 5V supply for the whole system where a GPS module is also included.
My main problem is that the GPS module is unable to find any GPS fix or satellites at all. Unfortunately I have no access to expensive hardware (oscilloscope, etc.) to make further debugging on this issue, but my first bet is the noise of the switching power supply. What kind of filtering could I put in front of the GPS module to eliminate the noise generated by the switching regulator?
Regarding the type of the regulator, I have tried both LM2576 and LT1376. If I remember correctly the LM runs at 52kHz and the LT is at 500kHz. In long term the LT would suit my needs better because it allows the supply to be build with smaller components.
