Thanks for your reply
But just to be sure
Are you saying the GPS by default will send data through all the above formats ((GLL, GGA, RMC, VTG, GSV, GSA) and in the PIC i will select the data i need
Or are you saying
i have to select the type of data or format up front (i.e. by programing the GPS to send only through the format I’m interested in, and so at the PIC side i only receive that data type or format.
Which of the two is closer or is the correct way things happen
Thanks again for your help, and looking forward to your reply
Regards
