engineer khan
Member level 3
i use all code from datasheet and also taken from net every command gives right response as desired but i type AT+CIPSTART="TCP","xxx.xxx.x.xx","xxxx"//ip and port
the response should be ok connect ok
but it gives ok and after a while it gives +pdp DEACT or status IP or connection fail what can be the solution please
o am using sim900d,rs232 hyperterminal,wish to communicate through tcp,APN,NAME ,USER name, DOmain Ip STATIC IP all things are known
