Good use for an old stepper motor------>use as an encoder
JabaThaSlut
Junior Member level 1
old stepper motor on sale
On my travels I came across this little gem :D
https://www.webx.dk/oz2cpu/20m/encoder.htm
Very nice idea for times when fairly hi resolution input method is needed. And best of all its cheap, most parts are probably in your junkbox.
Have fun
Jaba
robotman
Member level 3
Member level 3
use stepper as encoder
This is a great idea! I think that it works well for hand knob.
For robotic applications, it would not work well unless you overspec the driving motor. The overall moment of the armature and some of the magnetic effects would make it tough to use.
robotman
PeterG
Junior Member level 2
stepper motor gem
Hi Jaba,
Thx a lot for the link. Very nice (and very useful) idea!
Cheers,
Peter Gabriel :)
johnseven
Junior Member level 3
California
richardh rotenc
Jaba
Addition. If you read the article you'll understand.
For the "heavy knob" the author built, you can also use the flywheel found
in old radios, or in cassette recorders.
j7
panalog9
Full Member level 2
Full Member level 2
USA
how to use a stepper motor as an encoder
Another good description of this, with AVR source code
felix1200
how to use encoder stepper motor
Some years ago I built a similar circuit and made my experiences with it.
This kind of incremental sensor was only usful for armature application. It worked not so fine when the rotation was very slow.
When someone uses stepper motors with 4-coils a snap-in effect can be made by contact the not used coils together.
Make a simple short circuit to the not used coils.
An advantage is:
The output voltage of the used 2 coils increases (because of acceleration during snap-in effect) and the slow rotation sensitivity is much better.
Regards
felix1200
