74hc595 serial
I'm new here, I've found this very interesting forum by internet search and, so, I subscribed.
I'm writing because I'm going crazy with a very basic problem:
I'm using a PIC microcontroller to drive a Philips 74HC595 serial-parallel register. I've seen discussions about this here, I've downloaded a C example, too, and it contains exactly what I already knew (74HC595 should be very easy to use).
I cannot solve this:
I send a byte from the PIC to the register, it gets strange outputs (sometime the right one, sometimes another one), and after 2 or 3 times it gest stuck and the output doesn't change anymore.
I'm using ports a, d and e from PIC.
I've connected the two clocks together (shift and latch) so I drive both with a single PIC port. Then I close the byte with one clock cicle more (because the manual says that if you connect the clocks together shift is one step forward).
My system runs with a 10MHz clock, I set a huge pause between clock_up/clock_down (about 10x20x20 cycles).
Going crazy with this.
What can be the problem?
Maybe lack of pull-up resistors?
Maybe the wrong kind of outputs from the PIC?
Any idea?
Thanks a lot for any suggestion
Quinto
