GLCD problem with drawing - is it the library?
brucelee2
Member level 2
on a PCB
glcd_fill(0x00) not working
When i write to the right hand side of my GLCD (x position> 64) its works fine. IF I WRITE ON THE LEFT IT repeats on the right....
The thing is it writes text ok. Now as soon as i try to draw a circle its is not a circle but a mess. Im using a GLCD from Mikro electronica, there is a library for it(KS0107-samsung). Im wondering if anyone can point me to another library for it or maybe my GLCD is not working correctly--it is new.
SEE THE PICTURE --->
MY CODE:
could it be a timing problem? any ideas??? THANKS
char GLCD_DataPort at PORTD;
sbit GLCD_CS1 at RB0_bit;
sbit GLCD_CS2 at RB1_bit;
sbit GLCD_RS at RB2_bit;
sbit GLCD_RW at RB3_bit;
sbit GLCD_EN at RB4_bit;
sbit GLCD_RST at RB5_bit;
sbit GLCD_CS1_Direction at TRISB0_bit;
sbit GLCD_CS2_Direction at TRISB1_bit;
sbit GLCD_RS_Direction at TRISB2_bit;
sbit GLCD_RW_Direction at TRISB3_bit;
sbit GLCD_EN_Direction at TRISB4_bit;
sbit GLCD_RST_Direction at TRISB5_bit;
// End Glcd module connections
void main()
ADCON1=0xFF;
Glcd_Init();
while(1)
Glcd_Fill(0x00);
Glcd_Circle(64, 30, 10, 1);
delay_ms(5000);
Glcd_Fill(0x00);
Glcd_Write_Text("LEFT x=0", 0, 0, 1);
Glcd_Write_Text("Right x=65", 65, 2, 1);
delay_ms(1000);
_________________
PIC 18F4550-----20MHZ HS
GLCD problem NO IDEA...
with a KS0108 controlled GLCD you must use CS1 to access the first half of the GLCD, then swap to CS2 to access the seccond half... maybe your library isn't correct...
so which library are you using???
Re: GLCD problem NO IDEA...
Hi
Im using the mikroelectronica library, from their MikroC compiler. It is for this GLCD. hmmmm ive checked the lines, im thinking its a control problem as data is being receved sort of fine. im going to re build the lines today. ill keep u posted.
cheers:D
GOT IT WORKING
There was a problem with my RESET line. It works perfectly now. Thanks FOR your help thought.
