Give circuit diagram of F to V conveter
sangmeshwar
Junior Member level 3
f to v circuit
Please give me circuit diagram of Frequency to Voltage converter. IC 9400 is not available so please give me circuit diagrams using other ICs. Frequecy is 1 to 10KHz.
Thanks,
Sangmeshwar
f/v circuit
Monostable multivibrator output when averaged is F to V converter.
f to v converter circuit diagram
find the datasheet of ADVFC32 IC from analog devices(www.analog.com) ,This IC is F/V and V/F converter.
There are sch in datasheet.
ic 9400
I accidentally found this circuit in an old magazine, I hope that your
Dutch is as fluent as mine. :D
on1aag.
circuit f to v
hope it helps
hccp://www.ece.msstate.edu/courses/ece4522/projects/2001_spring/theremin/html/schematic.html
f to v convertor ic
you can also implement an F-V functionality using microcontroller.
ic-9400
Hi.
I used in the past LM2907 and work fine. Also some industrial F/V converters use this. Better for some boards is to use one H11L1 optocoupler, if the frequency is high.
Regards, even if is a late answer...:D
