Hello,
I am trying to plot the ac response of a gilbert cell multiplier. I have set the differential pair inputs as V1 + v1 and V1 - v1. For the quad transistors, I have given V2 + v2 and V2 - v2 as inputs. To perform ac analysis, I have set the quad pairs ac magnitude as 0 and the diff pairs ac magnitude as 1, now after performing the simulation, I get some weird results for the ac output response :sad:, but I am able to get an amplified version of the input at the output when I perform the transient simulation.
Is it the right way to do the ac analysis for a gilbert cell multiplier?
Also, could you please let me know, if the quad transistors should be biased to work in the saturation region? I have read in the books stating that the quad transistors work as switch, so is it necessary to bias them(quad inputs) to work in the saturation region?
Please help !!!
