Gf multiplier verilog code
vlsidesignshift1
Newbie level 2
I have written a code for GF(16) multiplier in XILINX but i am getting some errors.plz help me.
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
module mult4_4(
input [3:0]a,
    input [3:0]b,
    output p0,p1,p2,p3,p4,p5,p6,p7
 wire[15:0]w;
     wire[5:0]s;
     wire[10:0]c;
     and(w[0],a[0],b[0]);
     and(w[1],a[1],b[0]);
     and(w[2],a[2],b[0]);
     and(w[3],a[3],b[0]);
     and(w[4],a[0],b[1]);
     and(w[5],a[1],b[1]);
     and(w[6],a[2],b[1]);
     and(w[7],a[3],b[1]);
     and(w[8],a[0],b[2]);
     and(w[9],a[1],b[2]);
     and(w[10],a[2],b[2]);
     and(w[11],a[3],b[2]);
     and(w[12],a[0],b[3]);
     and(w[13],a[1],b[3]);
     and(w[14],a[2],b[3]);
     and(w[15],a[3],b[3]);
     HA HA1(w[5],w[8],s[0],c[0]);
     HA HA2(w[9],w[12],s[1],c[1]);
     HA HA3(w[10],w[13],s[2],c[2]);
     FA FA1(w[6],w[3],s[1],s[3],c[3]);
     FA FA2(c[1],w[7],s[2],s[4],c[4]);
     FA FA3(w[11],w[14],c[2],s[5],c[5]);
     assign p0=w[0];
     HA HA4(w[1],w[4],p1,c[6]);
     FA FA4(w[2],s[0],c[6],p2,c[7]);
     FA FA5(s[3],c[0],c[7],p3,c[8]);
     FA FA6(s[4],c[3],c[8],p4,c[9]);
     FA FA7(s[5],c[4],c[9],p5,c[10]);
     FA FA8(w[15],c[5],c[10],p6,p7);
     endmodule
THE above code is correct and i even got the required output but i am getting error in the next code which i wrote for polynomial reducer.
CODE:
8
9
10
11
12
13
module MUL(x,p0,p1,p2,p3,p4,p5,p6,p7);
input p0,p1,p2,p3,p4,p5,p6,p7;
output [3:0]x;
mult4_4 MUL1(.p0(p0),.p1(p1),.p2(p2),.p3(p3),.p4(p4),.p5(p5),.p6(p6),.p7(p7));
assign x[0]=p0^p4;
assign x[1]=p1^p5^p4;
assign x[2]=p2^p6^p5;
assign x[3]=p3^p6;
endmodule
THE error i got was
Uh, you have the mult4_4 outputs set as p0 thru p7, but then you drive them all with input p0 thru p7 in your module MUL.
So the tools are correctly telling you that you have multiple drivers.
I'm not sure how you expect this to work your mult4_4 instance doesn't even have the inputs a and b connected. Ah, I think this wrong hookup is due to the bad naming conventions you use...
BTW, your signal naming (lack of good signal names), the formatting of your code (there isn't any, nor is there any use of white space), and the use of antiquated module port declarations (using pre 2001 verilog module port declarations, though that is understandable as most of the websites are written by lousy Verilog coders)...all make your code harder to read and therefore more difficult to catch your own mistakes.
Also were you told to use Verilog gate primitives? Hardly anyone uses them for coding anything in Verilog. It is a lot easier to just use a behavioral description instead of a bunch of gate primitives.
Yes I have to write this code in structural so I have used gate level primitives.
So how should I write the second code that is the MUL module to get the required output as shown in the image?What is the mistake that I made while writing this code?Could you tell me...
I already told you, did you even read my post?
Read the first sentance.
