Mandar Joshi
Member level 2
Hello,
I am using STK600 and I have written code to read data from external dataflash using SPI interrupt and then put the same data on hyperterminal in PWM interrupt. But I get only first value of data byte as correct rest as 0x00. I also tried by using status register read command after receiving every single byte of data. There also I get the value of status register as 0x00.
My both PWM and SPI interrupts are working properly. Please tell me what is wrong with my code. Here is my code
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 #include <asf.h> //Slave select low #define cs_low() \ delay_us(10);\ PORTB=(0<<PB0);\ delay_us(10); //Slave select high #define cs_high() \ delay_us(10);\ PORTB=(1<<PB0);\ delay_us(10); char opcode_cnt=0; //Counts number bytes required before start reading actual data unsigned char data; //Variable to save save received data volatile char rd_cmplete_flg=0; //Flag is set after read operation completed int pg_addr; //Indicates address of page int buff_addr; //Indicates starting address of buffer volatile unsigned int i=0; //Counts number bytes read char pwm_init_flg=0; //Used only once in init_pwm() function char sample_count=4; unsigned char continuous_rd_flg=0,status_rd_flg=0; //continuous_rd_flg to trigger data read in ISR and status_rd_flg to trigger status register read void init_pwm(void); void spimstr_init(void); void spi_tx(unsigned char byte); void spi_tx_ISR(unsigned char byte); unsigned char spi_rx_ISR(void); unsigned char spi_rx(void); unsigned char get_status(void); void init_uart(void); void continuous_pg_read(unsigned int page_address,unsigned int buffer_address); int main (void) { // Insert system clock initialization code here (sysclk_init()). board_init(); init_uart(); spimstr_init(); continuous_pg_read(0x00,0x00); while(1) { if(rd_cmplete_flg) { rd_cmplete_flg=0; init_pwm(); } if(i>=23923) { break; } } // Insert application code here, after the board has been initialized. } void init_pwm() { if(!pwm_init_flg) { pwm_init_flg=0; DDRB = (1<<PB5); // set OC1A as output TCCR1A = (1<<COM1A1)|(1<<COM1A0)|(1<<WGM10);// set OC1A on compare match, clear OC1A at bottom // 8 bit fast PWM TCCR1B = (1<<WGM12)|(1<<CS10); // 8bit fast PWM and clock=8Mhz } TIMSK1 |= (1<<TOIE1); // enable timer 1 overflow interrupt } void spimstr_init() { //Master Mode Selected //MSB out first //Clock Polarity and Clock Phase selected as 1 //Clock Frequency 8MHz/128 selected SPCR|=(1<<SPE)|(0<<DORD)|(1<<MSTR)|(1<<CPOL)|(1<<CPHA)|(0<<SPR1)|(0<<SPR0); SPSR=(1<<SPI2X); } void spi_tx(unsigned char byte) { SPDR=byte; while(!(SPSR&(1<<SPIF))); //wait until transmission is completed } void spi_tx_ISR(unsigned char byte) { SPDR=byte; } unsigned char spi_rx() { while(!(SPSR&(1<<SPIF))); //wait until reception is completed return SPDR; } unsigned char spi_rx_ISR() { return SPDR; } unsigned char get_status() { unsigned char status; //high to low transition made on SS cs_low(); spi_tx(0xd7); //opcode to read status register of EEPROM status=spi_rx(); //Received the value of status register of EEPROM status=status & 0x80; //low to high transition made on SS cs_high(); return status; } void init_uart() { UBRR1H=0x00; UBRR1L=0x0c; UCSR1B|=(1<<RXEN1)|(1<<TXEN1); UCSR1C|=(1<<UCSZ11)|(1<<UCSZ10); } void continuous_pg_read(unsigned int page_address,unsigned int buffer_address) { pg_addr=page_address; buff_addr=buffer_address; while(get_status()==0x00); cs_low(); spi_tx(0xe8); //opcode to read page SREG=0x80; SPCR|=(1<<SPIE); } //ISR for Continuous Array Read mode ISR(SPI_STC_vect) { //PORTA=0xff; //LED port to ensure the working of interrupt //delay_ms(1500); if(!continuous_rd_flg) { opcode_cnt++; switch(opcode_cnt) { case 1: spi_tx_ISR((0x00)|(pg_addr>>7)); break; case 2: spi_tx_ISR((pg_addr<<1)|(buff_addr>>8)); break; case 3: spi_tx_ISR(buff_addr & 0x00ff); break; case 4: spi_tx_ISR(0x00); break; case 5: spi_tx_ISR(0x00); break; case 6: spi_tx_ISR(0x00); break; case 7: spi_tx_ISR(0x00); break; case 8: spi_tx_ISR(0x00); break; } if(opcode_cnt>=9) { opcode_cnt=0; //Reset to zero to repeat switch case if(rd_cmplete_flg==0) { data=spi_rx_ISR(); rd_cmplete_flg=1; } //Important Note //The buffer address and page address has to be incremented before cs_high() only then only this mode works if(buff_addr<263) { buff_addr++; } else { buff_addr=0; pg_addr++; } cs_high(); continuous_rd_flg=1; } } if(status_rd_flg) { unsigned char status; status=spi_rx_ISR(); status=status & 0x80; cs_high(); status_rd_flg=0; continuous_rd_flg=0; cs_low(); spi_tx_ISR(0xe8); //Resend continuous read opcode to read next byte } //PORTA=~PORTA; //delay_ms(1500); } ISR(TIMER1_OVF_vect) { //PORTA=0x55; //LED port to ensure the working of interrupt //delay_ms(1500); sample_count--; if(sample_count==0) { sample_count=4; TIMSK1=(0<<TOIE1); UDR1=data; while(!(UCSR1A & (1<<UDRE1))); i++; status_rd_flg=1; cs_low(); spi_tx_ISR(0xd7); //Send opcode to read status register } //PORTA=~PORTA; //delay_ms(1500); } void board_init(void) { DDRA|=0xff; //optput port for LED DDRB|=(1<<DDB2)|(1<<DDB1)|(1<<DDB0); //Direction of SS,MISO,SCK,MOSI pin selected }
