genetic algorithm (initial population)
nur hayati
hi all,
i'm new in matlab and GA.
i have a problem regarding the early stage of GA process. i have a little bit confusing in initializing randomly initial population. i have my own data set. then, why i have to initialize the initial population with random number? please help me. Thank you in advance.
to initiate the process you have to initialize the random numbers which is a initial guess to algo
i have my own data. so, i set the data as the initial population. then, how about the random numbers?
[what do you really mean by " i have my own set of data"?
i'm sorry if i'm wrong. what i mean is i have a set of data that contain 100 individuals. so, if i set my data as the initial population, do i need to initialize the initial population with random number? or, i can just proceed the initial population with my own data to the next step without generate random initial population? i hope you understand.
you can set your data as initial population.
it all depends upon your problem , whether you are able to converge to optimal solution quickly or not . and whether your initial data is near to or far from the solution.
ok. thanks a lot. so, now, i can proceed to selection process. thanks again.
