Generation of pulse using verilog
Venkatesh Satharu
Newbie level 2
Newbie level 2
In my project I want transmitter to be ON for 0.5µs and receiver should be ON for 1.5µs for that pulse generation please help me with verilog code in which I want switch between transmitter and reciever using a multiplexer my making use of this pulse generation code.
Thanks in advance & Regards
S.Venkatesh
What is the clock frequency which you have used in the project? One idea I can think of is,
If you have a 2 MHz clock ( 0.5 us period) you can write the code for a two-bit counter and generate the pulses accordingly. So you'll transmit when count==0 and receive otherwise.
Hi sir,
thanks for your reply. shall I make use of LFSR(linear feedback shift register) to switch between transmitter and reciever?
And my clock frequency is at 430MHz
