Sep 28, 2006 #1 R Rizwanishaq Junior Member level 3 Joined Sep 26, 2006 Messages 30 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Location Pakistan Activity points 1,583 18 khz wave Tell me how to generate the 18KHz square wave using 8051 microcontroller
Sep 28, 2006 #2 mehboob_iiui Full Member level 2 Joined May 20, 2006 Messages 132 Helped 8 Reputation 16 Reaction score 1 Trophy points 1,298 Location Rawalpindi - Pakistan Activity points 2,013 What about using a DAC with you microcontroller, this way you can generate a lot of waveforms. I am making a project in which I want to generate different waveforms using the PC and interfacing the DAC with the parallel port
Sep 28, 2006 #3 C cristianp Full Member level 2 Joined Jul 4, 2006 Messages 142 Helped 31 Reputation 62 Reaction score 21 Trophy points 1,298 Location Bucharest, Romania Activity points 1,909 A similar subject, for AVR:
Sep 29, 2006 #4 K KST Full Member level 2 Joined Dec 12, 2005 Messages 129 Helped 7 Reputation 14 Reaction score 0 Trophy points 1,296 Activity points 1,936 Rizwanishaq said: Tell me how to generate the 18KHz square wave using 8051 microcontroller Click to expand... Why do you use Timer 0 interrupt ???It's is very easy to do. In the KeilC complier, there is the good example for U ! You can download the demo version in the web (2K limited) www.Keil.com and then setup to see the example. Good luck for U !
