MaxElec
Junior Member level 3
Hi !
I need hardware suggestions for my test project.
I want to generate 10-100 HZ range thru picmicro but i need schematics on how to connect. The picmicro that am using is 16F914 and i will use internal osc.
The output of the mcu pin should be connected to small coil (coil outputs are connected together so u have just one wire coming out of the coil).
How should i make connection to the mcu and which other parts do i need (resistors etc. ), for generating those freq. per program.
If someone has some schematics on this, that would be great !
Thank you in advance !
