signalflow
Newbie level 5
Hi, I am trying to use the AD5412 (DAC). It requires an analog supply voltage AVdd of between 10.8V and 40V. I was thinking about using a step-up boost regulator such as LT1316 to generate a 12V DC output to supply the AVdd pin with on the AD5412. I am worried about the noise though since it is a switching regulator. Will this be acceptable if I put decoupling caps between the AVdd to AVss pins.
Or is there a better way to generate this voltage? I have a 24VAC input with a rectifier and then a LM2596 switching regulator to convert down to 5V DC supply voltage from the 24VAC input. So I just have a 5V DC supply.
