I am really confused how to generate total of 6V for my sensor bias. In my scheme I want to generate 6V for 1 chip (to bias the sensor) such that I can use it in serial powering mechanism.
Please guide me with some simple architectures. Please remember that I want to finally use it in serial powering.
The top chip( have to make a small circuit) will be connected to vdda(power supply) and other chip which is chip 2 (same circuit as in above chip) will be connected below with power supply as the ground of top chip and so on. The ground of chip 3 is 0.
Each chip i.e each circuit should generate 6V individually.
What I see is three rectangles with 6 volts coming out of them to diodes that flap around in space. Then, there's an invisible sensor and some random lines and scribbles.
Yes I would like to generate -6V which is below the ground and it is give to the PN diode. you can take anything as input.
the architecture should look like as shown below:
I need a small help from you regarding the design. Basically i need to design a startup switch which works as when we give input as 0 then output should be 0. and when we give 1.8V then output should be -3.6V. Please see the picture with this message.
I have designed a switch which works opposite (when input is 0 then output is -3.6V and when input is 1.8V then output is 0)and have attached with this message.
