[SOLVED] Geiger counter tube characteristics: please help!
meshgate
Newbie level 5
Newbie level 5
I found a geiger tube ( cilinder 130 mm x 20 mm diameter) about.
With the following label:
Type: X.A.1
s/n: 88151
op. volts: 1450
Window weight 7. mgm/cm^2
Made in England by DISTRON
Anybody can give me more details?
DISTRON website is not dealing with components, only instrumentation.
Try contacting them expressing your interests.
Sometimes you can get lucky!
1450 op. volts almost certainly refers to the DC voltage you will apply to the center wire. (Most schematics on the internet depict a lower power supply level, between 500 and 1000 V. I don't know whether this means your tube is more or less sensitive than the norm.)
The window weight probably has to do with a curved panel which slides around the tube, to cover and uncover an area which adjusts sensitivity to certain types of rays.
window weight is usually an indication of how thick the window on the tube is (and hence what will stand a chance of getting through it to be detected), heavy windows will tend to make the tube insensitive to beta and low energy alpha while having little effect on hard gamma and the like, while a thin window will allow detection of alpha and beta).
Lightweight thin windows tend however to be very delicate.
One thing to note with GM tubes is that the sensitivity is **strongly** voltage dependent as they cascade if the free electrons aquire too much energy.
GM tubes are fun.
Regards, Dan.
