i have problem with functional simulation in quartusII. it seems to be simulating but generated a lot of warning. most the output signals does'nt produced the desired waveform (i'm using the input stimulus via waveform, .vwi if i'm not mistaken). fyi, the VHDL code that i've written work on the other simulator, modelsim. and all the timing requirement is fulfilled.
so do i need to revise the code? or need to change quartusII settings, or else?
thanks in advance.
Added after 2 hours 27 minutes:
also, my reported simulation coverage is just 6.00%.
