Function Location in Keil 8051 [Resolved]
CMOS
Advanced Member level 3
USA
How do I place a function to a specific location in code memroy like using "ORG" directive in assembly?? I am using Keil 8051 Compiler.
Re: Function Location in Keil
Is it impossible?
It is possible,of course. But you do not specify which Keil compiler you have in mind. For example, in CARM compiler for ARM's, it is possible directly using language extensions directives, described in manual or web side. But most elegant method, and with sense for any compiler system, is using the separate name space in the code space and prepare proper linker maping definition directives. First, at compile time, the required code is placed in the separate segment, after that, at link phase, the linker place this part of code inside required absolute addresses inside the output. For every kind of the Keil compiler you can find proper commands and directives in the compilers and/or linker manuals.
bis
I am using Keil 8051 Compiler. I searched the manual for this but couldn't find anything about it!! :cry:
Re: Function Location in Keil 8051
hai
you can use assembly commands in keil
as it will support both assembly and c in the same program
but you must assure that this location willnot get mixupwith the
rest of the program
regards
sun
bis_ said:
start from this page, and read links carefully.
https://www.keil.com/support/docs/3006.htm
bis
No that doesn't solve my problen. I want to write personal bootloader for 89C61X2 within my main application such that application resides in the beginning of program memory (startig from 0x0000) and bootloader resides in the last block of program memory.
hi CMOS
plz
for what kind of problme you have to use fixed Add ?
there is no limitation for function location code,except for Interrupt functions.
it is possible to save the ADD of a function in a pointer .
Hi, I need to put the boot loader at the end of the program memory so that I can upgrade my application firmware using it whenever required. If both bootloader and application resides in same memory, it won't be possible to just erase the application area using bootloader, it will erase itself also. I hope you understand what I am trying to do.
Can you make 2 programs?
1 for the main loop;
and other for the BOOT loader.
then load into the uC the 2 programs, in 2 times.
regards.
Well I too was thinking of doing the same. But if its possible in Keil to locate a function, it would be easier to maintain the program!
you can configure the linker to put the code in a specific part of a memory.
see that image. what i did was say to the linker to put de program beyond the address 0x3000. in the memory map in the back you can see that is true, the code begins in the position 0x3000.
regards.
regards.
NO that will put my entire application at memory address 0x3000!!!
I just want one function to be loacated at say 0xFA00 and rest entire application from addres 0x0000!
My idea was to do that only for the boot program.
The rest of the program will be linked normaly.
And the address 0x3000 was only an example!
regards.
The rest of the program will be liked normaly.
regards.
That means I have to make 2 separate projects :(
I thought that the idea was that!
regards.
Ok solved this one too!! :D
You just have to go to Project-> Options For Target -> BL51 Locate and enter the following line in "code" text box.
Format is ?pr?function_name?file_name(address)"
Example: ?pr?start_bootloader?bootloader(FA00h)
Thanks all for helping.
