Full table of LCD commands (16x2 and 128x64)
Navid T
Full Member level 3
Iran
hello
i need full table of LCD commands ( 16 X 2 ) & ( 128 X 64 )
thank you
16*2 lcd commands
go to **broken link removed** and download the datasheets, you will find the commands there
www.geocities.com/dinceraydin/lcd/
there are vairous manufacture of LCD but most of them similar or the same the hitachi HD44780 chip
16 2 lcd commands
A detailed command set is available in :
"THe 8051 Microcontroller and Embedded Systems - Mazidi".
Generally problem with LCD occurs when delay between commands is not provided. This is required for internal processinf by the LCD controller.
$fe lcd commands
Look at Hantronix and Sharp-LCD site.
lcd 16*2 commands
Salam,
This may be some of the commands
$FE, 1 Clear display
$FE, 2 Return home (beginning of first line)
$FE, $0C Cursor off
$FE, $0E Underline cursor on
$FE, $0F Blinking cursor on
$FE, $10 Move cursor left one position
$FE, $14 Move cursor right one position
$FE, $C0 Move cursor to beginning of second line
$FE, $94 Move cursor to beginning of third line
$FE, $D4 Move cursor to beginning of fourth line
Hope i,ve helped u
hitachi lcd commands
You can get those commands in their respective datasheet!
