Full-digital audio amplifier
jetmarc
Member level 3
audio amplifier pure digital
Hi. I am looking for example designs of full-digital audio amplifiers. I want to use a 250mW speaker with minimum external parts, especially without DAC. There are about 2k FPGA gates available to be dedicated to filtering and PWM. The source quality is mono 8khz 8bit.
Any suggestions?
Marc
Burger King
Newbie level 6
I don't know if this could help you. I've found a Xilinx appnote on the implementation of sigma delta converters in FPGA (as far as I know it's the only way to avoid adding an external DAC).
Link: www.xilinx.com/xapp/xapp154.pdf
micijanus
Junior Member level 1
http://www.apogeeddx.com is the place to go,
And i would like to see the results of your efforts!
DDX2100 ic (i am looking for spice model)
also look at SA07 ic (spice available)
jetmarc
Member level 3
Thanks to both of you for the links. I have ordered samples of the DDX chip.
In fact I have a FPGA available in my circuit but I am a bit worried about the logic area necessary to filter the data. Did any of you actually implement such an amplifier in VHDL? I don't want to dedicate more than 2k gates to the audio (including DMA to fetch data from SRAM).
jetmarc
micijanus
Also look at the SA07 @ **broken link removed**
The more expensive 97$ 500KHz SA07 (DDX2100 4$)can take both analog & digital signals directly to the chip - no controller. They give good developement tools. And no values on their poposed PCB - and that is where i need help. The only point that i like more on the DDX is the Damped Ternary Advantage over Binary. But i do not know how to put a spice model together for DDX
THNKS
Uploaded file: SA07 Hi Fidelity AUDIO Amplifier.pdf
andy2000a
Advanced Member level 2
what is digital audio Amp ?? look like class-D amplifier
about audio Amp
class A --> good amp but efficiency =25%
class B --> have distrtion on signal =0
class AB --> bias on A<-> B use small bias
class C --> someone said Switch like Amp for RF
class D --> PWM amplifier ??? PWM is digital signal and use bridge + Low pass , it is digital audio Amp
, many toy chips use PWM driver speaker . but quality is poor
ynhe
Full Member level 3
China
Hi
It is impossible to simulate pure digital amp using SPICE.
The pure digital amp like apogee include Interpolation,Noise Shaping etc.
How to simulate using spice?
You may simulate using MATLAB.
The pure digital amp is not class D amp.
ynhe
andy2000a
I know what you said ..
digital amp == AC07 codec ssytem
it is pure digital and AC97 use delta-sigma D/A
deltaSigma A/D --> Nation semi or AnalogDevice have many paper
deltaSigma -> use C or matlab or hspice behavior simulation
but modulator is switch Comparator , it can simulation by spice , you can find many paper about it , but we usually matleb simulation system , hspice only simulation circuit
delta sigma D/A --> use digital filter --> codec analog chip
codec is Low pass filter
