sudarshann
Junior Member level 2
I have a fuel sensor in the bus which gives me 0-200 ohms.
The fuel gauge is connected to it and it works on 24V.
so the problem is i need an ADC to be connected to it. IF i connect the ADC device 0-5V (no idea on what is the potential divider in it)alone it works or gauge alone it works.
I want the both to work i cant get it right.
The sensor terminal gives me around 10V in half tank so i made this divider in the output
24V -> 780 ohms -> ADC tapping -> 100 ohms -> gnd.
It gives me arround 4 V and the voltage varitation is not that much good. the ADC device gives me only arround 70% to 90% of the reading if do so. the lower values are not got.
Please suggest me a solution for solving this.
Thank you
Thank you
