T
treez
Hello,
Is it the done thing to supply an 750W fuel pump motor with a 25 Amp current source switch mode power supply?
That is, the fuel pump motor is a Brushless DC motor which is driven by a H bridge, which in turn is supplied by a Current source SMPS...(the output of the SMPS is 25A maximum at 32v).
They say that the current source is partly adjusted by the tacho feedback from the motor....via a Frequency to voltage converter which goes into an error amplifier feeding the SMPS.
What I am wondering is, do the engineers know what they are doing?....I mean, surely all one needs to drive the fuel pump motor is the H bridge driver?...why are they wanting to use the current source SMPS upstream of the H bridge?
Is this a common technique?
