Druzyek
Newbie
I set up an FT232R on protoboard and now it is acting a little strange. It enumerates fine under Windows 7 when I plug it in but does not loop back data when I connect RX to TX. It was a few months ago when I soldered it on but as I remember it did loop data back at that time. I connected it to a microcontroller and can receive data fine from there to the PC. The odd thing is when I try to send data to the microcontroller from the PC. I have the microcontroller relay over TX anything it receives over RX (the same as loopback) once per second and when I first plug it in, it waits for my input as expected. It loops back any input I give it as expected but after the first character, if no input is available it continuously returns the number 176 (0xB0). It is as if the FT232 constantly spews that number out over TX unless it has received something else it is supposed to TX, in which case it does what it is supposed to.
The microcontroller and the loopback code seem good since everything works as expected when I try with an FTDI cable (TTL-232R.) The chip came from Mouser so I don't think it is a fake. Comparing EEPROM data between the chip and the cable was exactly the same except the serial numbers and the cable was set to use high current I/Os. The circuit I am using is the one on page 23 of the datasheet (https://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT232R.pdf) except I didn't have a ferrite bead and my microcontroller is running from the 3.3v output (it should be taking less than 10mA.) The USB line reads 5.1v and the 3.3v output is about 3.28v. Checking the resistance of all of the soldered pins shows that they are connected as expected and there don't seem to be any shorts.
Any idea what could cause this?
