I have tried to replace the while with a FSM model. But not successful in doing so. The output which is k is not passed to the output port.
1: while T[16] = 1 do // if (MSB bit of T==1)
2: T[16] = 0 //set the MSB bit to 0
3: T = T + (2**16 mod Y ) //and a precomputed value and if MSB bit is again 1 then repeat from line 8
return T
module fsm_model(clk,t,r,k);
input clk;
input [16:0] t;
input [16:0] r;
output reg [16:0] k;
reg state;
reg [16:0] g;
reg [16:0] h;
always @ (posedge clk)
begin
h = t;
state = h[16];
case (state)
1'b0:
begin
k = {1'b0,h[15:0]};
state = 0;
end
1'b1:
begin
g = {1'b0,h[15:0]};
h = g[16:0]+ r[16:0];
if (h[16:0] > 16'hFFFF)
state = 1'b1;
else
state = 1'b0;
end
endcase
end
endmodule
you state variable can never get into the 1'b1 state. When its 0 , it stays in 0 forever.
Why not show a simulation waveform, and show whatr the error is?
You need to learn FSM design and verilog in general. Start by the difference between blocking and non-blocking assignment. Then learn about FSM templates.
Please, for your own sake, learn the difference between blocking and non-blocking assignments and how they are used to model combinational and sequential logic.
Despite of other possible problems, the mentioned error is almost trivial and caused by a wrong polarity of rst that doesn't match the template for register synthesis. Presuming rst has active high level, you should write
Code Verilog - [expand]
always@(posedge clk orposedge rst)beginif(rst)
state <= s1;else
state <= next_state;end
Otherwise write if (!rst). The reported error line 42 is wrong.
The Xilinx's recommendation is not to use reset at all in the sensitivity list if it is not necessary like this time.
Use only clk like below to create flip-flop without additional control signals.
always@(posedge clk)beginif(rst)
state <= s1;else
This error at line 44 is valid because "h" (and indirectly "k" at line 44) could be updated on both - when "t" changed or when "state" changed at the same time.
Please check out FSM templates in ISE/Vivado for Verilog. I prefer to write synchronous one-always block for FSM (for working out next state and outputs all in the next clock cycle).
It's a different hardware description, omitting posedge rst in the event expression generates a synchronous reset while the original code obviously intends an asynchronous reset. Both have their purpose, but I don't believe that Xilinx considers asynchronous resets as unnecessary.
