Elektronman
Member level 5
Hello,
I'm working with a sample project for Digilent Atlys that can be found here:
https://tristesse.org/pub/atlys_ddr_test-20110731.zip
I have modified state 0 and state 1 of the FSM, so that it light some leds at certain spots.
( This is done mainly for debugging)
I have been working on this for a couple a days, but I really cannot understand why the Atlys gives out
an unexpected (for me) behaviour.
Here is the code:
As you can see, I have added to state 0, the following statements:
leds[0]<=0;
leds[1]<=0;
leds[2]<=0;
leds[3]<=0;
leds[4]<=0;
leds[5]<=0;
leds[6]<=0;
leds[7]<=0;
and, in state 1 I have added:
leds[0]<=1;
leds[1]<=1;
leds[2]<=1;
leds[3]<=1;
leds[4]<=1;
leds[5]<=1;
leds[6]<=1;
leds[7]<=1;
in state 1, I have commented state <= 2, so that the state halts on 1 and never goes forward (at this moment, the code doesn't make any sense,
I've purposely turned the Joelby code into a leds tester
These are the only modifications I have made to the code (apart from uncommenting the leds declarations in .ucf file
and adding leds as output and declaring them as reg).
I would expect the leds to light up when I run the example... instead. nothing happens.
But,
if I comment the leds[0]<=0...... leds[7]<=0 in state 0, then the leds do light up!!
So, does anyone know why leds don't turn on when running the code above? Am I doing something strange???
Here is the code:
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 21:56:56 07/31/2011
// Design Name:
// Module Name: atlys_ddr_test
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module atlys_ddr_test(
output DDR2CLK_P,
output DDR2CLK_N,
output DDR2CKE,
output DDR2RASN,
output DDR2CASN,
output DDR2WEN,
inout DDR2RZQ,
inout DDR2ZIO,
output [2:0] DDR2BA,
output [12:0] DDR2A,
inout [15:0] DDR2DQ,
inout DDR2UDQS_P,
inout DDR2UDQS_N,
inout DDR2LDQS_P,
inout DDR2LDQS_N,
output DDR2LDM,
output DDR2UDM,
output DDR2ODT,
output leds,
input clk // 100 MHz oscillator = 10ns period (top level pin)
reg [2:0] c3_p0_cmd_instr;
reg [5:0] c3_p0_cmd_bl;
reg [29:0] c3_p0_cmd_byte_addr;
reg [7:0] c3_p0_wr_mask;
reg [63:0] c3_p0_wr_data;
reg c3_p0_rd_en;
reg c3_p0_wr_en;
reg [2:0] c3_p1_cmd_instr;
reg [5:0] c3_p1_cmd_bl;
reg [29:0] c3_p1_cmd_byte_addr;
reg [7:0] c3_p1_wr_mask;
reg [63:0] c3_p1_wr_data;
reg c3_p1_rd_en;
reg c3_p1_wr_en;
reg c3_p0_cmd_en;
reg reset = 1;
// Outputs
reg [7:0] leds;
wire [6:0] c3_p0_wr_count;
wire [63:0] c3_p0_rd_data;
wire [6:0] c3_p0_rd_count;
wire c3_p0_rd_empty;
wire [6:0] c3_p1_wr_count;
wire [63:0] c3_p1_rd_data;
wire [6:0] c3_p1_rd_count;
wire c3_p1_rd_empty;
wire c3_calib_done;
wire c3_clk0;
// Instantiate the Unit Under Test (UUT)
ddr_interface ddr_interface (
.DDR2CLK_P(DDR2CLK_P),
.DDR2CLK_N(DDR2CLK_N),
.DDR2CKE(DDR2CKE),
.DDR2RASN(DDR2RASN),
.DDR2CASN(DDR2CASN),
.DDR2WEN(DDR2WEN),
.DDR2RZQ(DDR2RZQ),
.DDR2ZIO(DDR2ZIO),
.DDR2BA(DDR2BA),
.DDR2A(DDR2A),
.DDR2DQ(DDR2DQ),
.DDR2UDQS_P(DDR2UDQS_P),
.DDR2UDQS_N(DDR2UDQS_N),
.DDR2LDQS_P(DDR2LDQS_P),
.DDR2LDQS_N(DDR2LDQS_N),
.DDR2LDM(DDR2LDM),
.DDR2UDM(DDR2UDM),
.DDR2ODT(DDR2ODT),
.clk(clk),
.c3_p0_cmd_instr(c3_p0_cmd_instr),
.c3_p0_cmd_bl(c3_p0_cmd_bl),
.c3_p0_cmd_byte_addr(c3_p0_cmd_byte_addr),
.c3_p0_wr_mask(c3_p0_wr_mask),
.c3_p0_wr_data(c3_p0_wr_data),
.c3_p0_wr_count(c3_p0_wr_count),
.c3_p0_rd_data(c3_p0_rd_data),
.c3_p0_rd_count(c3_p0_rd_count),
.c3_p0_rd_en(c3_p0_rd_en),
.c3_p0_rd_empty(c3_p0_rd_empty),
.c3_p0_wr_en(c3_p0_wr_en),
.c3_p1_cmd_instr(c3_p1_cmd_instr),
.c3_p1_cmd_bl(c3_p1_cmd_bl),
.c3_p1_cmd_byte_addr(c3_p1_cmd_byte_addr),
.c3_p1_wr_mask(c3_p1_wr_mask),
.c3_p1_wr_count(c3_p1_wr_count),
.c3_p1_wr_data(c3_p1_wr_data),
.c3_p1_rd_data(c3_p1_rd_data),
.c3_p1_rd_count(c3_p1_rd_count),
.c3_p1_rd_en(c3_p1_rd_en),
.c3_p1_rd_empty(c3_p1_rd_empty),
.c3_p1_wr_en(c3_p1_wr_en),
.c3_p0_cmd_en(c3_p0_cmd_en),
.c3_calib_done(c3_calib_done),
.reset(reset),
.c3_clk0(c3_clk0)
reg [1:0] calib_done;
always @(posedge c3_clk0)
calib_done <= {calib_done[0], c3_calib_done};
reg [4:0] state = 0;
reg [11:0] count;
case(state)
0: begin
reset <= 0;
if (calib_done[1]) state <= 1;
//Elektronman: if I comment these below, leds do light up... why??????
leds[0]<=0;
leds[1]<=0;
leds[2]<=0;
leds[3]<=0;
leds[4]<=0;
leds[5]<=0;
leds[6]<=0;
leds[7]<=0;
end
1: begin
c3_p0_wr_en <= 1;
c3_p0_wr_data <= 64'd1;
//state <= 2;// Elektronman: the FSM is purposely stopped here
count <= 12'd0;
leds[0]<=1;
leds[1]<=1;
leds[2]<=1;
leds[3]<=1;
leds[4]<=1;
leds[5]<=1;
leds[6]<=1;
leds[7]<=1;
end
2: begin
c3_p0_wr_data <= 64'd2;
state <= 3;
end
3: begin
c3_p0_wr_data <= 64'd3;
state <= 4;
end
4: begin
c3_p0_wr_data <= 64'd4;
state <= 5;
end
5: begin
c3_p0_wr_data <= 64'd5;
state <= 6;
end
6: begin
c3_p0_wr_data <= 64'd6;
state <= 7;
end
7: begin
c3_p0_wr_en <= 0;
c3_p0_cmd_instr <= 3'b000; // Write
c3_p0_cmd_bl <= 6'd6; // 6 bytes
c3_p0_cmd_byte_addr <= 30'd16; // To address 16
c3_p0_cmd_en <= 1;
state <= 8;
end
8: begin
c3_p0_cmd_en <= 0;
state <= 9;
end
9: begin
count <= count + 1'b1;
if (count[11])
state <= 10;
end
10: begin
count <= 12'd0;
c3_p0_cmd_bl <= 6'd16;
c3_p0_cmd_instr <= 3'b001;
c3_p0_cmd_en <= 1;
state <= 11;
end
11: begin
c3_p0_cmd_en <= 0;
if (count[11])
state <= 0;
end
endcase
endmodule
leds[0]<=0;
leds[1]<=0;
leds[2]<=0;
leds[3]<=0;
leds[4]<=0;
leds[5]<=0;
leds[6]<=0;
leds[7]<=0;
leds[0]<=1;
leds[1]<=1;
leds[2]<=1;
leds[3]<=1;
leds[4]<=1;
leds[5]<=1;
leds[6]<=1;
leds[7]<=1;
But,
