Bimla Pandey
Newbie level 2
Hi friends,
Here is two codes for FSK Simulation in white noise but theoretical and simulated curve is not coming same. PLEASE correct following two codes of FSK Simulation if possible so that both Simulated and Theoretical curve coincide and reply me how I correct these codes.
CODE 1:-
% FSK Modulation
clc;
clear all;
close all;
%GENERATE CARRIER SIGNAL
Tb=1; fc1=2;fc2=5;
t=0Tb/100):Tb;
c1=sin(2*pi*fc1*t);
c2=sin(2*pi*fc2*t);
%generate message signal
N=1000;
m=randint(1,N);
b=1;
for EbNo=1:1:12
t1=0;t2=Tb;
for i=1:1:N
t=(t1Tb/100):t2);
if m(i)==1
m_s=ones(1,length(t));
invm_s=zeros(1,length(t));
else
invm_s=ones(1,length(t));
end
%message(i)=m_s;
%Multiplier
fsk_sig1=c1.*m_s;
fsk_sig2=c2.*invm_s;
fsk1=fsk_sig1+fsk_sig2;
fsk=fsk1/sum(fsk1.^2);
snr= EbNo + 10*log10(2);
ynoisy= awgn(fsk,snr,'measured'); %Noisy signal
%correlator
x1=sum(c1.*ynoisy(i));
x2=sum(c2.*ynoisy(i));
%decision device
if x1>x2
demod(i)=1;
else
demod(i)=0;
end
t1=t1+(Tb+.01); t2=t2+(Tb+.01);
end
[num(b),ratio(b)]=biterr(m,demod);
en(b)=EbNo;
BER_theory(b) = berawgn(EbNo,'fsk',2,'noncoherent'); % Theoretical BER
b=b+1;
end
err=sum(num);
ph=semilogy(en,(ratio),'r*',en,(BER_theory),'b-');
set(ph,'linewidth',1.5);
xlabel('Eb/No in dB');
ylabel('BER');
legend('Simulated','Theoritical');
grid on;
CODE 2:-
clc;
clear all;
close all;
f1=10; f2=5;
Tb=1;
N=1000;
x = randint(1,N); %input bits
% FSK modulation
b=1;
for EbNo=1:1:12;
for i=1:1:N
t=i:0.001:i+1;
if x(i)==1
y(i)=sin(2*pi*f1*t);
else
y(i)=sin(2*pi*f2*t);
end
ytx=y; %Transmitted fsk signal
ynoisy= awgn(ytx,snr,'measured'); %Noisy signal
yrx = ynoisy; %Received signal
end
%FSK demodulation
for i=1:1:N
yout1 = yrx(i).*sin(2*pi*f1*t); %multiply by carrier
ys1 =sum(yout1(i));
yout2 = yrx(i).*sin(2*pi*f2*t);
ys2 =sum(yout2(i));
%Threshold decision
if ys1>ys2
r(i)=1;
else
r(i)=0;
end
end
[num(b),ratio(b)]=biterr(x,r);
en(b)=EbNo;
pe(b)=0.5*erfc(sqrt(10^(0.6*EbNo/10)));
b=b+1;
end
err=sum(num);
ph=semilogy(en,(ratio),'r*',en,(pe),'b-');
ylabel('BER');
grid on;
CODE 1:-
% FSK Modulation
clc;
clear all;
close all;
Tb=1; fc1=2;fc2=5;
t=0Tb/100):Tb;
c1=sin(2*pi*fc1*t);
c2=sin(2*pi*fc2*t);
N=1000;
m=randint(1,N);
b=1;
for EbNo=1:1:12
t1=0;t2=Tb;
for i=1:1:N
t=(t1Tb/100):t2);
if m(i)==1
else
end
%message(i)=m_s;
%Multiplier
fsk_sig1=c1.*m_s;
%correlator
%decision device
if x1>x2
demod(i)=1;
else
demod(i)=0;
end
end
en(b)=EbNo;
b=b+1;
end
err=sum(num);
ylabel('BER');
grid on;
CODE 2:-
clc;
clear all;
close all;
f1=10; f2=5;
Tb=1;
N=1000;
% FSK modulation
b=1;
for EbNo=1:1:12;
for i=1:1:N
t=i:0.001:i+1;
if x(i)==1
else
end
end
%FSK demodulation
for i=1:1:N
ys1 =sum(yout1(i));
ys2 =sum(yout2(i));
%Threshold decision
if ys1>ys2
r(i)=1;
else
r(i)=0;
end
end
en(b)=EbNo;
b=b+1;
end
err=sum(num);
ylabel('BER');
grid on;
