Frequncy multiplier in verilog
skewed_clock
Junior Member level 2
Is it possible to create a frequency multiplier with verilog that can be implemented in a FPGA? That means given a input signal of frequency f can a circuit be made that calculates the frequency M*f ???
Either as a time-discrete ADPLL, you know about it, or using built-in hardware PLLs available with some FPGA families.
Actually I wanted to know how can i create another signal which has a frequency M times the input signal frequency where M>1. So that the signal generated has a frequency greater than that of the input frequency. ADPLL helps me get a signal which has a frequency lower than that of the input signal.
ADPLL can achieve frequency multiplication with an additional high frequency system clock.
What if my system has only one input and I need to generate a clock using that signal. Like I need to generate the clock for the K counter and ID counter (DCO) which are multiples of the clock signal given as input.
As said, you need a high frequency input clock or a FPGA with internal hardware PLL to generate it.
Making use of DLLs may help for your problem. Have the same signal passed through Delay loops to achieve a higher frequency for the input. I have not synthesized one, but have seen the concept of this in Xilinx.
You could use Digital Clock Managers (DCMs) which are provided by FPGA Vendor.
