div
Member level 3
frequency dependent rlgc
Guru:
I need your comment on extracting
frequency dependent RLGC of Transmission line.
For instance, because of skin effect, the
resistance per-unit-length is a function of frequency.
so are the other three--L,G and C.
Finally, user should get a R(LGC) Vs. frequency plot
of a transmission line given the geometry and material
setup.
You opinions are welcome as but not limited by below:
Software comparison: accuracy & speed.
Algorithm or closed-form equation.
Thanks.
Div
Guru:
setup.
Thanks.
Div
