Floating point? --> try integer solutions (what input values range, what expected calculation resolution and accuracy?)
What microcontroller, what clock frequency, what language, libraries and compiler do you use?
Consider creating a lookup table. Say you want two digits of precision... Then you need an array of 100 elements. Exponents are a simple matter of reversing the sign (positive to negative, negative to positive).
8Bit STM8S MCU, 16MHz clock, Timer clock - 250KHz, Expected freq input to the Timer Capture unit is 0-200Hz.
I haven't used Float variables and no Math or standard libraries. C language Cosmic Compiler.
Your requirements are restrictive; you could consider setting timer scaler to a interval between acquisitions as a rational number power of two, so that division could be replaced by a simple right shift (>>) operation.
For example, by setting timer period as 1,024s, the division operation can be made by right-shifting 10 digits, so if e.g 512 pulses are accounted during this time, the computed frequency is 500Hz with a reasonable resolution.
Needless to say that a timer with the largest magnitude should be choosen; many 8 bit MCU's have either 8 and 16 bits timers available.
If you perform only 1 measurement per second, 40 µs division time (0.004 %) would be absolutely no issue. But I guess 1 Hz is too slow. For reasonable measurement rate and resolution, you are tied to (multi-)periode measurement method and hence need division step.
Although the specification is incomplete (didn't mention measurement rate, resolution, minimal input frequency), I presume long unsigned (uint32) arithmetic is used here. Thus tables are hardly an option. However, if you choose a rate equal to the maximum input frequency of 200 Hz, what's the problem with spending 40 µs for the calculation?
